Opinions???
Locker and gears for the rear, installed for you is no more then $1800 ... there is no cheaper way then that. If you fell the need for the rear to be trussed the you need a D60 not a fancy D44.
I am trying to avoid getting a D60 because they are around $8k more than the D44, heavier, and decrease my clearance. And I don't need an axle that is that big.
The ECTED is an interesting idea, but seems to have failed somewhat in the execution. It is a clutch-based limited slip, that also has an electric activated selectable locker portion. The problem many people have with it is the clutches. They are a wear item, especially with offroad use. For a limited slip, the Detroit Truetrac is a much better choice. For an e-locker, you are already considering the Eaton. Ected? Find first-hand reviews from people who run them and read their opinions. Maybe the clutches aren't as big an issue as imagined.
Between the air and electric, it's just the actuation method. Used to be that the eaton e-locker for d44's was a weaker 2pin design, making the 4pin arb the stronger choice. But since eaton updated the design, many are favoring it just to not have to run air lines.
