Ordered K&N Filter
Old Jun 23, 2007 | 06:36 PM
HookNLadder's Avatar
I got mine (drop in) yesterday. I can feel a difference in power, which is nice. Sounds better. Not sure about MPG yet?
I have to find some time to stop jumpin on it to test that!
Old Jun 23, 2007 | 09:27 PM
jpaddict's Avatar
K&N is nothing more than a good rock screen. Hold one up to the light and see for yourself. I had one for a very short while on a 500hp Cummins. They flow more air but also flow more dirt.
Look elsewhere.
Old Jun 23, 2007 | 09:51 PM
bodybrdng's Avatar
Look elsewhere.
???? I have been using K&N in every vehicle I have ever owned and never had a single problem with them. You state that they are a good rock screen and flow more dirt..... Not to be rude but where is your proof or source of information, or is this just your opinion?
Old Jun 24, 2007 | 11:42 AM
fathomgreencamaro's Avatar
I wondered about this also. The K&N certainly passes
more light through and therefore more fine particulates.
Seems to run smoother with the K&N. The stock
filter shown had 10K on it. Not much fine dirt was trapped
during that time, mostly bugs.
See pics
ID:	2134   Click image for larger version
ID:	2135   Click image for larger version
Old Jun 24, 2007 | 05:47 PM
John L's Avatar
Look elsewhere.
If K&N's are nothing more than "rock screens" why are they still in business after more than 35 years? That amount of time is more than enough to bury a faulty product.
They have a solid product that actually does what they claim it to do IF it is maintained properly. I suspect the naysayers of K&N products don't fully understand how to care for them.
Old Jun 24, 2007 | 06:00 PM
rubiman's Avatar
I would lower it and put on some bling 22's and use the rest if the cash for woofers.
Old Jun 25, 2007 | 06:00 AM
hPOD's Avatar
I have a K&N on my 2000 TJ, and from personal expereince I can tell you -- it added no real power (other than sound), and does a HORRIBLE job at stopping dirt/dust particles from entering the intake.
It looks good with the hood up, though, but any percieved power gain is in your heads, especailly if you aren't "chip modding" the car. Since the onboard computer isn't designed for the increased airflow (thus doesn't even know about the increased airflow), the gas/air mix will be improper unless you "mod" the computer controlled injection to take that into account...and even then, the added "power" is a myth, IMHO. This is from an honest personal experience. I spent the money on the chip, the K&N and the less restrictive exhaust...and other than a weak attempt at trying to convince myself of a power gain, all I really gained was less money in my wallet and a louder Jeep, which I admit, did sound nice.
After a few months of using the K&N "bug filter", as I call it, detatch it from your intake and take a look inside...the entire inner ring will be coated in dirt/gunk...you'll need to clean that from time to time or you may feel engine pull from the compresser kicking on since the dirt/gunk buildup can prevent the intake from closing all the way, as it normally would. K&N's are far too porous...and like I said, if your computer controlled injection system isn't aware of the added airflow, the gas to air mixture ratio will be off -- thus you're "power gain" is rendered ... well, non-existant.
Old Jun 25, 2007 | 06:09 AM
John L's Avatar
Sounds more like a gasket sealing problem than an air filter problem. I've used K&N for years and have never experienced what you have seen.
Old Jun 25, 2007 | 06:18 AM
hPOD's Avatar
No gasket problem, the filter is simply sub-par at doing it's actual job...there is no real advantage of using one other than it sounds louder and looks better. Everyone that has ever used them talks about this "power gain", but I don't see it. I think it's more like a prideful denial that it added no power, but cost a little extra...
Old Jun 25, 2007 | 10:33 AM
Newtybar's Avatar
A less restrictive exhaust will increase power. I don't see how you could think it's all in your head. Go to a dyno and check it out yourself. MPG will increase, check your average mpg.
