parking structures
Guest
Posts: n/a
I wa wi=ondering if anyone knew the answer:
If I get a 2.5" lift will my JK fit most parking structures that are usually 6.5 ft in height? I would be running 33" tires
I would hate to get the lift and then find out I have to park it outside most mall or garages.?
ralph
ralph
You should be OK. I have 33's with 2" lift and I am right around that. Use your antenna as a warning guide.
According to Jeep.com with a hard top the Jeep measures 70.9" high or 5'10.9". I would add another 3" for the soft top which puts you at 6'2". Add a 2.5" lift on 33's (+1) and your at 6'5.5".
You might be tight.
You might be tight.
I am about 77.5" to the highest bow on my soft top. (46" to the bottom of my keyhole, 2 door, for a reference) That is with 35's and a 3" FT lift. My lift does seem to be higher than others I have measured against though! ???
Try the Mission Viejo Mall parking structure. They only have a 6'-0" clearance sign at the entrance
