parking structures
Old Oct 10, 2007 | 10:00 PM
crafa24
Guest
Posts: n/a
Default parking structures
I wa wi=ondering if anyone knew the answer:
If I get a 2.5" lift will my JK fit most parking structures that are usually 6.5 ft in height? I would be running 33" tires
I would hate to get the lift and then find out I have to park it outside most mall or garages.?
ralph
Old Oct 10, 2007 | 10:05 PM
Rubimon's Avatar
I have a tall 3" lift and 35's, I havent found anyplace I dont fit yet.
If you want I will measure my height tomorrow. It will be with the soft top though.
Old Oct 10, 2007 | 10:11 PM
crafa24
Guest
Posts: n/a
thanks...i live in California and the structures here have all sorts of plumbing going through the parking spaces.....jaaja sure hate to have some crap fall on my JK..anyone else have problems?
Old Oct 10, 2007 | 10:20 PM
par4bmw's Avatar
You should be OK. I have 33's with 2" lift and I am right around that. Use your antenna as a warning guide.
Old Oct 11, 2007 | 03:53 AM
BigJerm's Avatar
you SHOULD be ok. I know with 2.5" BB and 35" tires my Jeep is about 6'5 or 6'6 and depending on the angle the entrace has i come close to hitting the 6'8" warning barrier above
Old Oct 11, 2007 | 06:41 AM
wayoflife's Avatar
JK-Forum Founder
LOL!! Try the Mission Viejo Mall parking structure. They only have a 6'-0" clearance sign at the entrance
Old Oct 11, 2007 | 07:15 AM
bcperry2000's Avatar
yeah you shoudl fit. i'm on 3" and 35's and haven't foudn anywhere i don't fit either. of course everything is bigger in texas though.
Old Oct 11, 2007 | 07:30 AM
Rubimon's Avatar
Ah, sorry, I wouldn't know, I don't hang at the malls!
I just keep it parked in my garage where it is easier to keep clean!
Old Oct 11, 2007 | 07:37 AM
redWRANGLER's Avatar
According to Jeep.com with a hard top the Jeep measures 70.9" high or 5'10.9". I would add another 3" for the soft top which puts you at 6'2". Add a 2.5" lift on 33's (+1) and your at 6'5.5".
You might be tight.
Old Oct 11, 2007 | 08:24 AM
Rubimon's Avatar
I am about 77.5" to the highest bow on my soft top. (46" to the bottom of my keyhole, 2 door, for a reference) That is with 35's and a 3" FT lift. My lift does seem to be higher than others I have measured against though! ???
