Pic request for 2.5" lift with 34" tires
Old Aug 25, 2013 | 07:17 PM
Matthewd5's Avatar
Originally Posted by bobafetske
How big do the 285/75/17's end up being?
I have the 285/70/17's and here is a link to a metric to inches converter and it said it was like 32.7
http://tire-size-conversion.com/metric-tire-conversion/
Sent from my iPad using JK-Forum
Old Aug 25, 2013 | 07:18 PM
Matthewd5's Avatar
Originally Posted by aaronstephen
Here's my setup.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=491820"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=491821"/>
Nice look, how wide are those tires? How many psi are you running?
Matthew
Old Aug 26, 2013 | 12:58 AM
aaronstephen's Avatar
Matthew
Thanks
Tires are 12.5" wide and I'm running about 28psi in them.
Old Aug 26, 2013 | 06:17 AM
Matthewd5's Avatar
Thanks
Maybe it's the black on black look but they look bigger and definitely wider
I keep wanting to either get my factory wheels dipped in black or go way out there and get a set of ATX Slabs but at $399 x5...
I've been trying to spend my $$ only on things that are performance related and not much on things that are more aesthetics
Matthew
Old Aug 26, 2013 | 06:36 AM
blue project's Avatar
AEV 2.5" lift with 285/75/17 Nitto Terra Grapplers. Mounted they measure 33.5".
Old Aug 27, 2013 | 05:48 AM
Rileycoopah's Avatar
Default 2.5" teraflex spring kit with 315/75- 16 general grabbers
I could make them rub by fully flexing the rear end, they would just touch the edge of the flare. I did have to trim the rubi rail back about an inch. The generals measure 34.75"Click image for larger version
ID:	492322Click image for larger version
ID:	492323Click image for larger version
Old Aug 27, 2013 | 08:36 AM
SpicedCrusher's Avatar
I have 315/70/17 which measure right around the 34-34.25" range.
285's will be a lot closer to a 33" and probably even less when measured.
Old Aug 27, 2013 | 09:18 AM
TJJK's Avatar
Our 285/75/17 KM2s measure 33.5 tall at 35 psi.
Old Aug 27, 2013 | 09:41 AM
flatattack's Avatar
2.5" Rubicon Express with 315/70 17 Goodyear Duratrac's
Old Aug 27, 2013 | 09:50 AM
cgn152's Avatar
Nice!!! Did you have to use spacers?
