Please help!!!!!!
Old Sep 27, 2012 | 06:23 AM
09jku's Avatar
Originally Posted by mandor6863
I have a 2010 unlimited and installed the same kit. I had no issues as you state. Could be difference between models but I find that strange.
I removed the sway bar arms from the front, removed the shock from one side, lifted the frame (floorjack) while axle is left on block. To do this I removed the tire, lowered the rotor onto a block of wood and positioned the floor jack to the frame. Raised the frame and removed the spring. Tight to squeeze the new spring in but removing the front brake hose from frame helped. Once spring was in, I lowered the frame back down and placed the new shock in. Re position jack , jack the differential up and install new tire. Move to opposite side.
I did not remove anything other than the sway bar links which get replaced by new ones in the kit, if I remember, you use the front in the rear.
Axle does sit 1" off center but it has caused no real issues and I will fix that this fall.
I have over 35k miles on the kit and all has been fine.
Mandor6863
thank you everyone for the advise!! mandor6863 I tried like a champ to do it like u stated but there was 0% chance it was gona work on mine that way and in the instrcutions it says the longer coil to the front if i put the smaller it would have been cake for sure. I hope it wasnt a misprint
Old Sep 27, 2012 | 09:30 PM
09jku's Avatar
Ok thank you everyone! I like to say " f#%* you lift kit! I finally kicked your ass! " lol hours in it was about 8 and now after work Tomarrow will be the task of a RC stubby bumper with my warm 9.5 ti winch! Wish me luck I hope this goes smoother lol. Btw the lift came out great and rides great!!! :-) (0 ||||| 0)
Old Sep 27, 2012 | 09:37 PM
carolinajk's Avatar
absolutly nothing beats the feeling you get from doing it yourself ! good job , on your winch install make SURE the cables are secure and dont rub ANYWHERE , put split hose around the positive if you have to. you would be amazed how fast cables can rub through , i have seen equipment BTFU from rubbed through battery cables causing shorts . again congrats on you job well done
Old Sep 27, 2012 | 09:38 PM
09jku's Avatar
Oh and RC. Your written directions are horrible! With that said though your customer service guys and phone support where unmatched and outstanding. ! Thank you to everyone that helped and I will be using those directions for kindling be certain of that lol
Old Sep 28, 2012 | 04:07 AM
mandor6863's Avatar
Glad to hear you have it in. Seems there must be some differences in the years of vehicle and configurations. One thought I had was that mine was new and only 700 miles on it and yours is a year older with miles on it. Might have been suspension components settling or becoming stiff due to use. Might have made things more tight.
Still, you worked through and completed. Congrats.
Enjoy and stay safe.
Mandor6863
Old Sep 28, 2012 | 05:26 AM
09jku's Avatar
From this to this to this
ID:	371532   Click image for larger version
Old Sep 28, 2012 | 06:26 AM
1978cj7jk2012's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=371531"/>
Looks great! What sliders are those?
Old Sep 28, 2012 | 06:48 AM
carolinajk's Avatar
looks awesome now you can get bigger tires !
Old Sep 28, 2012 | 08:01 AM
09jku's Avatar
Ugg I shlda bought 35s but was worried bout that Dana 30 holding up. And I'm not sure on the sliders I was lucky on bought it with them on there lol So il save up so when I do tires again its 35s or 37s as there is enough room but I'm still weary of that d30
Old Sep 28, 2012 | 08:50 AM
BossierCity_Jk's Avatar
I would love to know how to make the d30 hold 37s without worrying about it
