Please Help
Old May 6, 2014 | 10:13 PM
Todd2291's Avatar
Default Please Help
After installing a 2.5 in RK lift and new 35's I had some gear work done also sleeves and gussets. I aquired a clicking coming from the front DS area. The faster I go the louder it gets. Almost sounds like a baseball card in a bicycle spoke. It's def rotational. Going down hill with the motor killed I can still hear it. Also driving on the highway I get a vibration. Anyone know if this is a front Driveshaft going or a problem in the T case.
Old May 6, 2014 | 10:29 PM
Chefbrujo's Avatar
Maybe a u-joint?
Old May 6, 2014 | 11:02 PM
TX_JK's Avatar
Did they forget to put gear oil back in the front diff? Did you have the ring and pinion replaced? Maybe they didn't get a good pattern and you are hearing your gears making noise. If it was a u-joint i would think you would hear it chirping. If it was a problem with the transfer case you'd hear it in the middle of the jeep not under the front.
Have a buddy walk beside your vehicle as you drive it to see if they can pinpoint where the sound is coming from. It might sound like its coming from a different location outside the vehicle.
Old May 7, 2014 | 03:46 AM
Rebar-7's Avatar
You could pull the front DS and drive it see if it makes noise then !
Old May 7, 2014 | 04:12 AM
Todd2291's Avatar
Yeah it sounds like it could be coming from the T Case area.its def not the front dif. EVO did the gear work and I have to believe they didn't forget to put gear oil in it. Also I had the stealership take a look. Of course they say the noise is normal but also check the front and rear dif and said that looked great.
Old May 7, 2014 | 06:42 AM
suprablaski's Avatar
I wouldn't assume because a great shop did the work mistakes can't be made, even the most skill professional can have absent minded moments that's why we call it human error and not idiot error lol, but sounds like your tracking the noise away from the diff anyways
Old May 7, 2014 | 06:53 AM
mattyk's Avatar
Veteran: Navy
check the rubber boots on your drive shafts, both front and rear. if one is torn it could be smack something which would make it go faster and louder as you go faster.
Old May 7, 2014 | 07:30 AM
Todd2291's Avatar
Yea when I get home tonight I'm going to pull the front drive shaft off and see if the noise is still there
Old May 7, 2014 | 08:53 AM
Donttread's Avatar
The boot is going to be a thumping noise. Grab your front driveshaft at the pinion and check for play. Your front ds could be bad or you could've lost torque on your pinion.
Old May 7, 2014 | 07:59 PM
Chefbrujo's Avatar
Ive had bad ujoints before (not on jeep) and it was clearly a clicking sound that was speed specific. Also it wud do so without power coasting down a hill. I wud check them cuz thats pbly a lot cheaper fix than something else in that area. Worth a look anyway.
