PLEASE HELP !!! Another Bump stop question !!!
I have a '14 JKU with 4" springs, 35" tires, stock fenders, shock length extended 24.63", collapsed 14.87"...How much bump stop do I need? And which are the best to get ? I am really worried about damaging the shocks.
How much? Until your tires stop rubbing against places they shouldn't. It's a trial and error because with the measurements you provided, you appear to be thinking that there is some formula you can follow. You can't, there are too many variables. As for shock damage, those should be fine once you start flexing and stop the rubbing, the shocks are fine at that point.
lowjack989 (12-26-2017)
Between this thread and your other one, you've gotten the real answer. There is no simple formula to determine proper bumpstop. This is one thing that many people don't understand. They think that just cuz they bought a lift that has bumps included, those are automatically the proper length stops to use, but that is not necessarily the case. The only way to really tell is to cycle your suspension. You've heard that term a few times now. Unfortunately it's kinda a pain in the rear to do. Realistically, you need to remove the coil, and jack up that corner of the axle. what you are looking to do is prevent the tire from stuffing in the well completely, and prevent the shock from compressing completely....whichever of those might happen first (different on every jeep depending on suspension lift, tire size, shock length). Up front you're gonna have to remove the spring in order to install bumpstop anyhow. It's really best if you just get something that is adjustable like the metalcloak ones....that way you can increase or decrease bump in 1" increments as needed.....or if your lift changes over time, forcing you to change the bump lengths. One realworld example would be if you install something like the EVO RockStars in the rear. Those would raise the rear shock mount, and hence change the distance the shock can travel before full compression. Anyhow, cycle the suspension and measure the proper length of bump to avoid fully stuffing the tire, or fully compressing the shock. That's the only way to really do it right.
If you cant take the time to do it right just throw some 3" bumps on there and you will be covered for a 35x12.5" tire that is on a wheel with 4.5" of backspacing.
I'm more worried about the shocks...Also, now looking at limiting straps,ugh. So, just use the same method to measure them, by cycling the suspension, correct? I want to do this correctly but it'd be a helluva lot easier if there was a calculation to use
3" of bump stop will cover your shocks compressed length, again since you don't want to take the time to properly cycle and measure.
Not that I don't want to, it's that I can't, I don't have access to a shop and I have to rely on a local mechanic to do it. I just don't want to waste money on them cycling it and measuring then have to put it back together and buy the parts and then take it apart again.
edit to add to the list of things you'd need above.....guess you'd need a drill and bits as you need to drill a hole in the front spring perch to install bumps.
lowjack989 (12-27-2017)
