Plug and Play Remote Starter $100 on ebay
Old Feb 1, 2014 | 05:40 AM
  #51
BuckeyeDave's Avatar
Got mine yesterday. Installed it in 15 minutes and works great. Thanks for the fleabay listing!
Old Feb 1, 2014 | 06:12 AM
  #52
Kentgu3's Avatar
I get mine on tuesday, glad to know it's that easy to install ! Great find guys.
Old Feb 1, 2014 | 06:47 AM
  #53
KevinMac's Avatar
Mine is now on order too!
Old Feb 1, 2014 | 07:50 AM
  #54
RST JK's Avatar
Order mine the other day, received it in about 3 Day. JUST installed it. Start to finish took about 30 min. Works great! My only issue (or just something different)....once I turn the Jeep off and take the key out of the ignition, the horn honks and the doors lock (nearly instantly). Anyone else's do this?
Old Feb 1, 2014 | 08:06 AM
  #55
DunnyBunny's Avatar
JK-Forum Ambassador
Curious myself. That doesn't sound right.
Old Feb 1, 2014 | 08:27 AM
  #56
RST JK's Avatar
UPDATE: Only locks and arms by itself if I don't drive the Jeep anywhere, basically autostart it, get it, and shut it off. (was trying out the system). My guess is that it is a safety feature.
I just auto started it, got in, drove around the block and shut it off. Everything operated as normal. I will keep you posted with any changes. I emailed the ebay seller just to be safe.
Old Feb 1, 2014 | 08:39 AM
  #57
Brass Knuckles's Avatar
I think I may have ordered the non-TIP start version instead of the TIP start version. Hopefully, it won't matter. We shall see...
Nevermind...I'm all good according the Car Alarm.
Old Feb 1, 2014 | 01:00 PM
  #58
Namtaru's Avatar
Mine does the same when i drove it it didn't do the honk and lock right after.
I got mine in from ebay today, it took longer to remove the stupid steering column than it did to install the actual starter.
after about 25 minutes I was done and it works wonderfully.
$100 well spent.
Old Feb 1, 2014 | 02:15 PM
  #59
Dan5677's Avatar
Has anyone tried it on a manual yet?
Old Feb 2, 2014 | 04:29 AM
  #60
DonP's Avatar
Will this work with a aftermarket remote security system or do you need oem
