Plug and Play Remote Starter $100 on ebay
Old Feb 10, 2014 | 06:53 PM
  #151
bob-o's Avatar
Originally Posted by LidLess07X
I use my chin. Seriously
Same here, its works way better
Old Feb 10, 2014 | 07:05 PM
  #152
Namtaru's Avatar
For reference...
http://www.youtube.com/watch?v=_jACSPipPSE
Old Feb 11, 2014 | 08:02 AM
  #153
Vladimer's Avatar
Originally Posted by Woodbutcher
Amazon was screwed up, I got mine 4 days after ordering. It will work on a manual, but I don't recommend it without implementing some sort of safety protocol. I bought it to test it out, and you will have to bypass the clutch safety switch. I plan on using a relay connected to the e-brake and a toggle switch to complete the circuit. That way it will be a 2 step process for it to work, maybe hide the switch.
That's a good idea actually. So essentially to start it you need to have the ebrake engaged and also have your toggle switch to "on" for example?
Old Feb 11, 2014 | 04:34 PM
  #154
Woodbutcher's Avatar
exactly, pull up your e brake and then turn on your switch.
I figure a relay wired to put out a ground instead of being hot and then use that switch to interrupt it.
I'm still trying to figure a way to incorporate a neutral safety switch...right now I leave the t-case in neutral.
Old Feb 12, 2014 | 02:47 PM
  #155
Vladimer's Avatar
Its been awhile since I've popped off the boot to see what the plate looks like but here is a clever solution. It is not the most elegant but it does seem to be practical.
Custom Neutral Safety Switch-5 Speed
Old Feb 12, 2014 | 03:08 PM
  #156
Thanks for the link, I heard it about that once before but wasn't quite sure the way of going about it. Maybe when the weather warms up
Old Feb 12, 2014 | 05:53 PM
  #157
ShutterBug's Avatar
I thought this was a joke, until I tried it. OMFGosh!
Old Feb 13, 2014 | 07:38 AM
  #158
jmill012's Avatar
Ok. So maybe I'm just an idiot but I can not figure out what two yellow wires to splice!?!?!?
Anyone what to help me out with some pictures or direction? I looked at the one photo on here but honestly couldn't figure out what I was looking at..... :shrug:
Old Feb 13, 2014 | 09:11 AM
  #159
Vladimer's Avatar
Has anyone tried hooking up an external antenna to get more range out of this unit?
EDIT: Actually just realized, this uses the factory remote and the remote still connects to the Jeep ... meaning there is no additional remote and this unit does not have an antenna in it ... that right?
Old Feb 13, 2014 | 09:56 AM
  #160
Correct. The t5 harness and the evo I believe, are used with aftermarket alarms. It just so happens it can be used as a remote start on Chrysler / Jeep vehicles. If you what the video the installer states that the added an extended range remote setup. But you would end up with 2 remotes.
