Poison spyder
Old Dec 26, 2011 | 05:08 PM
  #61
Nwapache's Avatar
Originally Posted by SergeantChuck
Just finished the install of my rear crusher flares. Anyone else have a hard time finding a 17/32 drill bit? I ended up using a 1/2 bit and worked the hole until the rivnut fit. Read directions first!!!
Dude ... I told you that drill bit was a bitch! Did you figure out the rear brackets?
Old Dec 26, 2011 | 05:21 PM
  #62
SergeantChuck's Avatar
I know where the large brackets go but it is a tight fit. I have not installed them yet. They go up against the back wall of the fender well that is perpendicular to the tire. The two slots in the bracket line up perfectly on the already present fender bracket. You have to fight like hell to get them up in there. The small bracket that goes on the front side of the fender does not fit well. At least not on my JK. Three holes line up but the fourth was off the pinch weld metal. I have not installed either yet but I will this weekend. I used bearing grease on the washers of the tool supplied for the rivnuts and never had to swap out the washers. Got all the rivnuts on both sides installed in less than an hour.
I also know where the three brackets for the front inner fender liner go. I will install most of this Saturday. I'll take pictures.
These were a little bit of work but look awesome now that they are installed.
Old Dec 26, 2011 | 05:25 PM
  #63
Just went back and read your first message to me. You did warn me about the drill bit. I guess I got excited after getting the fronts installed. Thanks fore trying to warn me. And you are right, you can't just get that 17/32 bit anywhere. I looked all over town with no luck.
Old Dec 27, 2011 | 12:12 PM
  #64
rubi3's Avatar
Just dropped my Brawler Lite with Bar off to be powder coated this morning. Can't wait to get it back!!
Old Dec 27, 2011 | 12:33 PM
  #65
Did you grab the lock nuts and washers from the eight studs inside the bumper before dropping it off? Just asking.
Old Dec 27, 2011 | 12:52 PM
  #66
rubi3's Avatar
Yup. And I told them to tape my bolts off before doing whatever they do.
Old Dec 27, 2011 | 03:28 PM
  #67
I fought to get my original lock nuts off. Soaked them with penetration oil the night before. But the Brawler went on easily. Still have not figured out how to put some color behind the spider so it is more visible.
Old Dec 27, 2011 | 07:18 PM
  #68
Boosted's Avatar
2011 Brawler JK with the following Poison Spyder Customs parts....
* Brawler Lite front bumper with Brawler Bar and skid
* RockBrawler rear bumper with tire carrier and Hi-Lift mount
* Crusher Flares front and rear
* Crusher Corners with LED tail and reverse lights
* Brawler Rockers rocker armor
* Extreme Duty trans mount and crossmember
* Lightbar mount for 50" Rigid.
* Poison Spyder Customs grab handles / fire extinguisher holder
* Bombshell diff covers front and rear
As previously mentioned, these parts are top notch and built to be used and abused.
Old Dec 28, 2011 | 05:10 AM
  #69
Purchased the Rocker Knockers and JKBralwer Rear Bumper yesterday. Northridge is still giving the 5% off as of yesterday but it won't last much longer they said.
Old Dec 28, 2011 | 05:28 AM
  #70
Cervelo's Avatar
Did they say when you would get them?
