Pulling left / rear axle not centered
Old 10-30-2014, 12:26 PM
  #21
Invest2m4's Avatar
Originally Posted by Dlampe
Is your wheelbase the same left to right?
This is called rear toe (I said wtf first time the alignment shop said they adjusted it). Essentially, the toe should be identical side to side, meaning the axle is perfectly parallel to the front axle. My arms were set to the same length, but it was still off. Once adjusted, it no longer pulled.
Old 10-30-2014, 12:36 PM
  #22
Maertz's Avatar
Damn what size tires? I believe the larger the tire (or more sidewall) the harder it is to notice this as the tire can move side to side more on the rim to help it drive less noticeably. I need to get mine on an alignment rack to get mine all dialed in eventually.
Old 10-30-2014, 12:42 PM
  #23
14Sport's Avatar
Which is why I adjusted my front axle using the lower CAs to be square with the frame. I then adjusted the rear axle to be parallel (square) with the front axle.
Old 10-30-2014, 01:37 PM
  #24
Former Vendor
Rock Krawler Suspension's Avatar
Originally Posted by mds22
My adjustable rear track bar just arrived, I'm installing it tonight when I get home. After I get my axle exactly centered(close as possible ) then I'll let you know. As of now the prob has not been solved. Next step will be to even out the caster on both side instead of the factory .03* difference. I have a procal and I know my steering wheel is exactly centered. I'll post later tonight
Let us know where you're at on this issue, We just saw this post.
RK
Old 10-30-2014, 04:38 PM
  #25
kjeeper10's Avatar
That is your thrust angle ?
Toe would be like the front, tires closer together in the front or rear. All JK's seem to have toe in the rear which is not adjustable.
Correct me if im wrong !!!
2007 Rubicon /2 door/6 speed
Old 10-30-2014, 04:42 PM
  #26
Dlampe's Avatar
The total amount of toe can not be changed in the rear but you can balance the amount of toe left to right built into the axle with adjustable arms.
Old 10-30-2014, 05:34 PM
  #27
mds22's Avatar
Originally Posted by Rock Krawler Suspension
Let us know where you're at on this issue, We just saw this post. RK
RK I'm a big fan. Love your quality
Adj Rear track bar installed, rear axle is centered to 1/32 of an inch. "Pulling to the left" is still there, but I can notice a difference. It is better, but definitely still pulling. Change lanes in less than 3 secs at 65mph. Any thoughts??
Wheel base is perfect left to right.
Old 10-31-2014, 12:38 PM
  #28
Former Vendor
Thanks, thats what we shoot for!
What size and kind of tires do you have on the rig again?
RK
Old 10-31-2014, 01:24 PM
  #29
mds22's Avatar
Thanks, thats what we shoot for! What size and kind of tires do you have on the rig again? RK
35/18/12.5 TrailGrapplers
Old 06-16-2022, 08:44 PM
  #30
Art Amador's Avatar
did you ever resolve the pull issue mds22?
Quick Reply: Pulling left / rear axle not centered
