Question about offset wheels
Old Dec 2, 2012 | 09:03 AM
Alan_Scott's Avatar
Default Question about offset wheels
In the next week or so I'm planning on ordering the bfg T/A ko's in a 33/12.50 15 set up. With that of course a set of 15 inch wheels. With a 2.5 in. RC suspension lift, my question is should these be okay without having to put spacers on or possible rubbing with the brake calipers?? The wheels are -27mm offset so I am still not sure. Feedback would be awesome!!!
-Thanks
Old Dec 2, 2012 | 09:23 AM
Smashboogie 4x4's Avatar
Former Vendor
I have the 15x8 Cragar Soft 8's with a 4" backspace.
These wheels are close to the caliper but so I run a 1/8th spacer. You could also just take a little bit of a grinder to the caliper to clearance it for the wheels. The caliper has a ridge on it (from the casting mold) which can be ground down to achieve the clearance you need.
Old Dec 2, 2012 | 09:58 AM
inspect-a-home's Avatar
Im running 15x8 steel wheels but will replace them soon with 17" beadlocks. Couple things going with 15s is that you got to get the right backspacing, I have 3.75" and I barely had to grind down the front brake calipers. Try to stay away from spacers to get the right amount of backspacing. Also, upgraded my tie rod w/ the HD Pro Rock krawler and it barely fits, gets like 1/4" close to wheel weights. Combined with the right air pressure and tire mine rode pretty good in the highway, just don't take corners like a sports car and you should be fine.
Name:	RK tie rod.jpg
ID:	394225   Click image for larger version
Name:	RK tie rod 3.jpg
ID:	394226   Click image for larger version
Name:	2011-04-23 17.29.17.jpg
Old Dec 2, 2012 | 10:08 AM
Alan_Scott's Avatar
What kind of backspacing on a 15 can be okay without having to grind down the caliper? If possible? Sorry if I dont know much on this, barely starting out!! Lol
Old Dec 2, 2012 | 10:22 AM
3.5" would do, grinding took 2 mins and I only grinded like 1/16" off the front calipers.
Old Dec 2, 2012 | 11:28 AM
Alan_Scott's Avatar
Cool!! Im guessing the offset helps with some clearance too??
Old Dec 4, 2012 | 08:12 AM
Psywar's Avatar
Sorry to thread jack:
Wheel Spacers will ruin the Jeeps suspension wont they?
This is my first large vehicle, but I know with my other cars a lot of people used spacers to put wider tires on their rides.
I was told that the spacers will actually mess things up over time.
I don't know if this is true or not.
I want to get wider tires on my stock wheels and stock suspension setup.
I was looking at going with the 285/75/16 but I was told I would need that 1.5" spacer to do this..
It is kind of putting me off from doing this.
Old Dec 4, 2012 | 09:08 AM
Atch's Avatar
No it's not true. You can run spacers without damaging your components.
Old Dec 4, 2012 | 05:14 PM
Psywar's Avatar
Thank you for the reply!
