Question: Installing Windshield Lights
Old Feb 13, 2008 | 03:30 PM
lawsonj3's Avatar
Default Question: Installing Windshield Lights
I am going ot install two KC Slimlights on KC windshield mounts. Has anyone used some type of gasket beween the mount and the surface. I don't want to risk scratching the surface and causing rust. If so what did you use?
Old Feb 13, 2008 | 03:55 PM
cim330's Avatar
use the warping foam paper that comes with the lights
Old Feb 13, 2008 | 03:58 PM
lawsonj3's Avatar
Do you think that it will trap moisture? I actually considerd it already.
Old Feb 13, 2008 | 04:00 PM
mjolnir's Avatar
I thought it came with a rubber gasket
Old Feb 13, 2008 | 05:17 PM
riverzendz's Avatar
They do come with some sort of gasket.
Old Feb 13, 2008 | 05:22 PM
DeepSky's Avatar
My KC brackets came with nothing but the metal brackets.
Old Feb 13, 2008 | 05:34 PM
lawsonj3's Avatar
The box was factory sealed with the brackets in sealed plastic...no gasket of any type...recommendations? I am considering inner tube material or something similar.
Old Feb 13, 2008 | 05:48 PM
pkdailey4's Avatar
That Will Work
Old Feb 13, 2008 | 06:01 PM
dmwil's Avatar
I took a calendar that is a refrigerator magnet and cut it to the right shape and put it between the brackets and the paint. It was perfect. It is a rubber-like material that has just enough softness to protect the paint, but I also believe it will possibly slightly dampen some vibration, too.
Old Feb 13, 2008 | 07:13 PM
cenhockey55's Avatar
i jus got a thin rubber sheet from my work and made my own
