quick Disconnects
I need to get some quick disconnects. I want ones where the sway bar is secure when i disconnect them. What is a good brand to get? I was looking at the JKS quicker disconnects but it doesn't look like you can secure the sway bar when disconnected.
(I like the idea of just removing a pin when disconnecting the sway bar)
Thanks
Thanks
Teraflex Quick Disconnect Install
TF QDs for 0-3" Lift
TF QDs for 4-6" Lift
JKS are adjustable, which is why many folks prefer them. But, you can add the TF stowage hardware to the JKS package (or most any other for that matter) ...
TF QD Stowage Hardware
That sounds like the Teraflex ST Dual Rate Swaybay system. Nothing to disconnect. You reach in on one side, pull a knob out to a detent position and it is released. When you are almost on the road you turn the knob to release it. When it lines up, it reconnects itself. It is a complete sway bay replacement though.
