quick Disconnects
Old Apr 13, 2010 | 09:22 AM
Butler20's Avatar
Default quick Disconnects
I need to get some quick disconnects. I want ones where the sway bar is secure when i disconnect them. What is a good brand to get? I was looking at the JKS quicker disconnects but it doesn't look like you can secure the sway bar when disconnected.
(I like the idea of just removing a pin when disconnecting the sway bar)
Thanks
Old Apr 13, 2010 | 09:43 AM
Butler20's Avatar
the rough country have a great price on theirs. thank you!
Old Apr 13, 2010 | 09:47 AM
Butler20's Avatar
with the rough country ones you have to drill into the frame. Are there any where it uses the stock holes to secure the sway bar?
Old Apr 13, 2010 | 10:47 AM
Mark Doiron's Avatar
Teraflex. You can buy the TF stow pins separately for about $25-30 (IIRC) if you prefer another brand of QDs. Here's a write-up on the TF QDs ...
Teraflex Quick Disconnect Install
Old Apr 13, 2010 | 11:05 AM
rozzman10's Avatar
i was worried about drilling the frame too.. but it wasnt a big deal.. just measure twice and drill once.. looks good and works great.. RC is def the way too go IMO
Old Apr 13, 2010 | 11:32 AM
Steven4est's Avatar
damn any one have a link to these? you just remove on pin and thats it? its compeltely secured?
Old Apr 13, 2010 | 11:47 AM
redrockin7's Avatar
Love my teraflex ones... pull pins, rotate up, pin to stow-away mounts on the radiator core or whatever it is....
Old Apr 13, 2010 | 11:53 AM
moabjk072d's Avatar
I also vouch for the Terflex one's, very easy to install and use.
Old Apr 13, 2010 | 02:06 PM
Two hitch pins--one on each side, rotate up then secure with the same pins. TF has two different lengths, depending on how much lift you have ...
TF QDs for 0-3" Lift
TF QDs for 4-6" Lift
JKS are adjustable, which is why many folks prefer them. But, you can add the TF stowage hardware to the JKS package (or most any other for that matter) ...
TF QD Stowage Hardware
Old Apr 13, 2010 | 02:56 PM
Vernnz's Avatar
http://www.teraflex.biz/products/ter...rangler-jk?p=2
That sounds like the Teraflex ST Dual Rate Swaybay system. Nothing to disconnect. You reach in on one side, pull a knob out to a detent position and it is released. When you are almost on the road you turn the knob to release it. When it lines up, it reconnects itself. It is a complete sway bay replacement though.
