Quick install question side marker light issue.
So I was just installing my Bushwacker flat flares but for some reason my side marker lights wont work.
I did the fender chop a while ago so I haven't had the side markers wired up for a while now, but they were working fine before I did the chop.
I don't think I did anything wrong, cut the clip going to the old side markers, and added connectors to the wires and plugged them both in but nothing.
Suggestions?
I can't finish the install until I get the lights working.
Suggestions?
any good. One thing I am not sure is: does LED light require exact match of
+/- (fire/ground) connection or is it swappable?
It sounds like they are wired up wrong or you blew a fuse, do any of the parking lights work
MBRP Tech 112-21-2009, 05:51 AM
The wires are reversed...I did the install on our 2 door a few weeks ago and had the same problem. Red goes to black, not red to red and black to black. Its pretty stupid, but give that a try.
ry32912-21-2009, 07:41 AM
Yes what mbrp tech1 said. LED,s only work one way if the polarity is wrong they will not light
wolfmanii12-23-2009, 06:13 PM
swapped ground/fire connection now the marker light is good now.
THanks for all the help
MBRP Tech 112-24-2009, 09:29 AM
Glad you got them working...Kind of a pain considering you have to rip the fender off that you just installed...been there done that.
