Re-designed Teraflex Ball joints?
Ok....now that I'm back on track
. What's the tips on re-installing these axles and the fiberglass washers? I'ld like to not F this up!
I notice they're kind of bowed. Does the bow point towards the bell housing or towards the wheels?
A lot of people just discard the those plastic guides. They are just helping "guide" the shaft by holding it at a height it passes through the axle seal. The only real trick, whether you leave the guides on or take em off, is grease the splines a bit and use a steady hand to carefully guide it in. Just don't go jamming it in all willy nilly or you might be replacing axle seals in the near future. If you leave the guide on, I'd just flip it so it's bending a bit towards the diff.....so you're pushing it against the bend rather than with the bend. When brand new, those aren't bent at all, but they bend a bit over time. Again, only function they have is helping insert the shaft.
Oh no, the seal is pressed in from inside the diff towards the tubes....and if you have a leaky seal you get to yank the axles shafts back out and pull the carrier out of the pumpkin. Usually straight forward.....but you know...you've not had the smoothest ride with a lot of this crap.
Usually there is just one guide on there. Wonder if the shop that did your u-joints slapped another one on.
Gonna have to delay my trip, where we had planned on leaving tonight but in the current state, it's looking like a tomorrow afternoon departure.
Well, I finally wrapped this job up. I had planned to replace my passenger wheel bearing hub but ended up replacing the driver side as well since the speed sensor broke off of both hubs and I couldn't extract the plastic inside the hub. I tried drilling it out, only to notice the bottom part fell into the hub which I couldn't fish out of it. I ended up going to Napa and getting another hub....and Yozza!! $145 for a Napa hub. I paid $85 for a Crown online which looks better than the Napa. They had it in stock and I didn't feel like dicking around trying to find a lower price one, so bit the bullet. I ended up going to the dealer and getting a new axle nut so I now have 2 matching 35mm nuts. Whoever put that 34mm on there didn't do me any favors because it looks like it had a slightly finer thread and they cross threaded some of my axle yoke threads.
Glad to be done
- New TF HD ball joints installed
- Both front wheel bearing hubs replaced
- Steinjager sway bar disconnects installed
- Power stop Z36 front brake pads
- Shop installed axle U-joints
- 90% complete on dash cam install currently functional.
All set, it all seems to be working good so far.....I'm ready to roll!
Glad to be done
