Rear Solid Diff Cover warning
Old Oct 1, 2007 | 08:08 PM
Rubimon's Avatar
I know WOL has a dif cover and full tractions 3 lift, I have asked him to chime in.
Old Oct 1, 2007 | 08:30 PM
wayoflife's Avatar
JK-Forum Founder
Actually, I have Rockcrusher covers (same thing) on my TJ but not on my JK. However, I do believe they should fit and clear a Full Traction track bar. If they make contact, there is a good chance that you have your axles shifted too far out.
Old Oct 1, 2007 | 10:47 PM
2K1TJ's Avatar
I assume it's just one of the "fins" that's making contact, right? If the interference is only minor, just grind off the offending area. If you don't have a hand grinder, now's a good excuse to get one. Get a 4-1/2" one. If you have a Jeep, this won't be the last time you'll need it!!
Old Oct 2, 2007 | 07:28 AM
easttnruby's Avatar
Not trying to hijack but I have the SOLID cover up front and my FT track bar rubs on it while off roading as well as rear. WOL, I checked the shift on the track bar and the axles are dead center. Does it need to NOT be centered and if so left or right.
Old Oct 2, 2007 | 10:23 AM
seer1's Avatar
Did SOLID change its design?
I'd post a pic, but.... Here's a link instead http://www.northridge4x4.com/proddet...OLID-DIFFCOVER
Old Oct 2, 2007 | 11:01 AM
jsmoriss's Avatar
Originally Posted by excrider450
he has to mean track bar. I noticed my adj. full traction bar rubs just enough to scratch the finish on dynatrack diff cover. I also get mild rubbing on the passenger spring as well.
Just to add my 2 cents... :-) My FT front trackbar was rubbing on my Riddler front diff. I had to shorten the front-top arms and grind the diff cover a tad. In the back, the trackbar bolt knocked on the bump stop. I flipped the bolt but I'm also hearing a 'popping' noise back there once in a while. I wonder if the rear passenger coil might catch the trackbar once in a while.
js.
Old Oct 2, 2007 | 11:05 AM
jsmoriss's Avatar
Originally Posted by flyer415
Thanks for posting those pix. I was getting ready to buy a 3" lift with adj track bars and the Solid diff cover. Anybody know if there is a cover that doesn't protrude as far or is the blame on the curve of the bar.
If you have adjustable control arms, you can set them up to avoid rubbing. My front upper control arms are 1/8" shorter than stock, and the lowers are 1/8" longer. I had mild rubbing until I ground the Riddler diff cover. I think the SOLIDs don't protrude as much.
BTW, I got less rubbing on the diff cover with the HD front coils.
js.
Old Oct 3, 2007 | 02:12 PM
joeschonert's Avatar
Default solid diff cover
those pictures show the guard that just resides over the stock cover. i weant with the solid bolt on replacement covers and have no issues with the track bar or anthing else for tha matter.
Old Oct 3, 2007 | 03:21 PM
hotdogging's Avatar
Bump on any more info on this.
I am planning to get a set of adjustable track bars from full traction and a set of diff covers for my teraflex bb waiting to be installed so my axles are lined up and good to go just in case they are not. I don't have adjustable control arms like jsmoris does to prevent any rubbing.
Could this be a few isolated incidences, anybody else with full traction track bars want to chime in?
Thanks
Old Oct 3, 2007 | 05:17 PM
DirkDigler's Avatar
In the part number "catalog" that Solid provides all of its retailers, it reads BOLDLY that their Dana 44 covers will NOT fit on JK applications due to interferance with the trac bars. Talk to the company that sold them to you.
