Regearing
Old Mar 18, 2023 | 03:32 PM
  #21
RickLB's Avatar
Vet Army
Thanks for all the info y’all, it does help clear my mind some.
Most of the wheeling will be forest service roads and trails around the USA. Something like the Smoky mountain 1000, trails in Colorado, Maine , Kentucky and so on.
No hard core rock crawling.
Old Mar 20, 2023 | 08:49 AM
  #22
BLK HOLE's Avatar
Originally Posted by XJRefugee
So you are saying 4.88 is not not deep enough and that he go with 5.13 's ? I thought that after 4.88's the gears got weaker? increased changes of breaking teeth
I have 5.13s and 39s on both a JK and a JT. No issues.​​​​​​​
Old Mar 20, 2023 | 08:51 AM
  #23
BLK HOLE's Avatar
Originally Posted by resharp001
Primarily a concern with D30s and hard wheeling. OP does not have a rubi, so guessing we are talking about a front D30. Lots of X factors in use. I can't recall what tires OP was running or wanted to run.
Also, more gear relieves driveline stress.
Old Mar 20, 2023 | 10:42 AM
  #24
resharp001's Avatar
Loved
Community Favorite
My point just being.....there will ALWAYS be a weak link in any setup. For a D30 with 5.13s, that weak link is the pinion gear. That doesn't mean it it not adequate, but for some folks that are going to add traction control and push that axle in big rocks.....when something gives, it will likely be those pinion gear teeth.
Without going into lengthy backstory.......I'd tell you guys I got a PR60 rear axle that, for reason, has hubs with 5x5.5 wheel pattern. It was delivered to the original purchaser with 1/2" wheel studs instead of the 9/16" studs ordered. Would anyone care to guess what the weak link is in a PR60 with eaton locker rolling around on 115lb MT tire/beadlock combo while using five 1/2" wheel studs rotating those tires/wheels around? There's nothing like being 8 hours from home in the boonies and noticing there are a few things missing.
Old Mar 21, 2023 | 03:21 PM
  #25
Bison_22's Avatar
I just re-gear my willys with a set of Yukon 4.88s and noticed a whirl sound from 0-25 MPH. I was in the break-in period when I noticed this.
I used the same setup on my Gladiator with no issues
shop listened and diagnosed a bad bearing so I'm getting that replaced as I write this.
Old Mar 29, 2023 | 07:02 AM
  #26
RickLB's Avatar
Vet Army
Well, since Revolution has a miscount in their warehouse, I’m going 4:56 gears. They may not have 4:88s for a few months. 😂
Old Apr 11, 2023 | 05:19 PM
  #27
RickLB's Avatar
Vet Army
Got the Jeep back today and now the fun starts…heat cycles and break in
Old Apr 12, 2023 | 04:55 AM
  #28
resharp001's Avatar
Loved
Community Favorite
Just for the record, and since we were talking Yukon up higher, bearings are almost never bad right outta the box. Poor install and improper preload is what causes quick death of a bearing.
Hope all goes well. It's nice to have a jeep that drives as it should ​​​​​​​
Old Apr 12, 2023 | 05:26 AM
  #29
BLK HOLE's Avatar
Yukon has a rep for noisy gears these days.
Old Apr 15, 2023 | 04:20 PM
  #30
RickLB's Avatar
Vet Army
You’re right about that. Just over a hundred miles so far on the gears and man what an improvement over those 3:21’s
