Regearing Question
So rite now I'm running 33" tires and want to regear, I know 4.56 are ideal for 33's but I'm planning on upgrading to 35's within a year or two so I would rather run 4.88's for 35's. Is it ok to run the 4.88's for the time being until I get 35's or should I just go with the 4.56's. I have a 12 4dr with a 2.5" RK max travel lift. Open to all suggestions and input is appreciated.
Well if your going to be opening your rears consider lockers now, I also have a 12, mines on 35's currently with 3.21's I just ordered 4.56 gears lockers master install kits chromoly front axle shafts sleeves and gussets for the Dana 30. If you pm me ill let you know how much and from who.
I went with 4.56 because on the 12 auto that puts me at 600 rpm more at 65 vs the stock set up
Look at the attached chart
