Relocating the steering stabilizer
Old Feb 27, 2008 | 11:51 AM
thissideup's Avatar
Default Relocating the steering stabilizer
When replacing the steering stabilizer do you need a kit for relocating it or do you move the original hardware??? I just replaced mine with a Ranchero shock back into the original position and I'm worried about smashing it.
Old Feb 27, 2008 | 11:57 AM
bly109's Avatar
Woods makes a nice bracket to relocate it. PM him, he should be able to help you out.
Old Feb 27, 2008 | 02:28 PM
jsmoriss's Avatar
Originally Posted by Gros Chien
We have also set up the Shock to the drag link instead of the of the Tie Rod.
Interesting... I see you also used a trackbar drop bracket. If you'd used the top-most bolt on the axle bracket for the trackbar, the geometry with the flipped drag link would have been off a bit, giving you some bump steer, right? Did you use the trackbar drop bracket to re-locate the shock, or re-locate the shock because you were using a trackbar drop bracket? :-D
js.
Old Feb 27, 2008 | 02:34 PM
jsmoriss's Avatar
That ABS line looks kinda tight!
js.
Old Feb 27, 2008 | 02:40 PM
Gros Chien's Avatar
js.
The drop bracket is from the Rubicon Express long arm lift kit.
We have mount it this way so it get up higher and protect it a little more.
It is also when you turn the tie rod move back and fort and the shock move whit it. I'm not sure about the bump steer. I'm not full knowledge about this kind of stuff. I'm just telling what I know about my set-up.
Sorry if I'm not more of a help.
JM
Old Feb 27, 2008 | 03:10 PM
jsmoriss's Avatar
The drop bracket is from the Rubicon Express long arm lift kit. We have mount it this way so it get up higher and protect it a little more. It is also when you turn the tie rod move back and fort and the shock move whit it. I'm not sure about the bump steer. I'm not full knowledge about this kind of stuff. I'm just telling what I know about my set-up. Sorry if I'm not more of a help.
Who did your lift? SDL Suspension?
js.
Old Feb 27, 2008 | 03:36 PM
Gros Chien's Avatar
js.
Extreme Gear Off Road in Sacramento California
Old Feb 27, 2008 | 03:58 PM
CIJeep's Avatar
Originally Posted by N2rock
put the Woods one on my Sunday
Your shock is on wrong, the stem should be up. There is a TSB to fix that problem and they usually give you a new shock to boot.
Speaking of which, given the nature of Jeeps it is a good idea to boot all your shocks and protect the stems so they don't wipe out a shocks seals.
Old Feb 27, 2008 | 04:04 PM
Gros Chien's Avatar
Thank you for this I will fix it for sure...
Old Feb 27, 2008 | 04:07 PM
CIJeep's Avatar
js.
I'm trying to understand why the manufacturer thinks a 2 bar suspension is better than a four? Also seems like a good setup to wipe out a u-joint sooner.
