Relocating the steering stabilizer
Old Feb 27, 2008 | 04:12 PM
CIJeep's Avatar
Originally Posted by Gros Chien
Thank you for this I will fix it for sure...
Not yours, it was correct. N2Rock was the one that was backwards.
The stem should be connected to the red bracket. If you look at the bracket it appears that if could cruch part of the shock at extreme articulation.
Old Feb 27, 2008 | 10:16 PM
MD_Rubi's Avatar
Originally Posted by N2rock
put the Woods one on my Sunday
do you have the url for woods?
Old Feb 28, 2008 | 06:46 AM
jkkat's Avatar
Default Woods web site
Username: jeep
Password: forum
UN and PW are case sensitive.
www.4XFiX.com
Old Feb 28, 2008 | 02:36 PM
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
Wait a minute- I just looked at the TSB http://project-jk.com/images/tsb/TSB_19-003-07REVA.pdf and it says the correct orientation is the rod end should be connected to the tie rod, the body end connected the axle bracket... This is how mine is connected. I think you have yours backwards
Sorry for the slow response, but I just found this thread.
To use my bracket, you need to mount the rod end to the relocation bracket. The quote, "If you look at the bracket it appears that if could crunch part of the shock at extreme articulation" is mostly accurate. Most importantly flipping the SS end for end will prevent the shock from making contact with the bracket. No so important is the fact that this contact will happen when the steering wheel is turned hard to the left and not during extreme articulation.
I didn't know that there's a TSB out for the SS direction, but I had noticed that the new JK's have the rod end attached to the axle. I just went and read the TSB. It sounds like you may need to show proof of a leak, to get the TSB work performed. At least that's my interpretation of the TSB. Would be good to hear what folks are running into at the dealership. Thanks for posting up this info. I'll spread the word.
And thanks for posting up the details about the kit and website.
Old Feb 28, 2008 | 05:10 PM
CIJeep's Avatar
You're right about the current TSB, I know the shock on my Jeep is just like yours, and somehow I misread the TSB.
But the stem up makes more sense to me, get the shaft out of harms way and away from road debris. I was holding off on rotating mine until I had a boot to protect the shaft if its not too late.
Sorry
Old Feb 28, 2008 | 06:39 PM
Woods's Avatar
JeepSWAG
We should keep in mind that the shock boot debate is very much like many other Jeep debates i.e. it's more effective to buy an X and build it up, than to buy a Rubicon...
I'm not offering my personal opinion, however there are many people who would tell that shock boots are typically very bad for shocks in most Jeep environments.
Old Feb 28, 2008 | 06:50 PM
joe002's Avatar
Not to hijack this thread, but why?
Old Feb 28, 2008 | 07:17 PM
Woods's Avatar
JeepSWAG
Here's a link to a thread about shock boots.
SHOCK BOOT THREAD
The claim is that they hold dirt and moisture in...
I bet it depends on what type of wheelin you do. Mud, Crawling, Sand... actually determines which is better. I'm also willing to bet that generally there's not a giant difference.
Old Feb 28, 2008 | 07:28 PM
Dayton's Avatar
I recently cut my boots and found... my rear passenger side shock was bent. Just for that reason (and the fact that there was a bit of Trabuco mud in two boots) I won't put a boot back on any shock.
Old Feb 29, 2008 | 04:59 AM
joe002's Avatar
Woods and dayton1999 – thanks for the info. Even with “simple” changes there’s always more to think about.
