removing shift knob
Old Jun 11, 2009 | 05:52 PM
  #31
bombaman18's Avatar
MAN THIS SITE IS FREAKIN AWESOME!
I HAVE SUBSCRIBED TO THIS SITE FOR LIKE 3 DAYS AND HAVE FOUND ANSWERS TO ABOUT 15 QUESTIONS I WOULD HAVE HAD A TOUGH TIME TRYING TO FIND OUT FOR MYSELF, INCLUDING HOW TO REMOVE SHIFTER KNOB. THANKS TO ALL FOR YOUR TIME AND JK ENTHUSIASM.
Old Feb 8, 2010 | 11:29 AM
  #32
murdoc319's Avatar
i know someone asked it but its been left unanswered. has anyone measured the circumference of the main shifter shaft?
Old Feb 10, 2010 | 11:48 AM
  #33
murdoc319's Avatar
Originally Posted by HankFard
Actual size is 0.580", about 37/64; closest to 9/16 or 0.5625". There are NO threads on the shaft, just a notch and a flat area to accomodate the standard POS knob. The T-case shift lever is the same design, but closer to 7/16 diameter with the same notch and flat area. Both knobs are press on, pop off style - and they are known to rattle.
Before I get yelled at - i used the search bar but nothing came up, tried it again and it worked, found the answer to my own question already posted on the forum
Old Jun 23, 2010 | 07:41 AM
  #34
Prairie Dog's Avatar
Originally Posted by jameswharton
Before I tear something up, does anyone know the proper way to remove thre factory shift knob. I am looking at putting something a little more ergonomic on.
Thanks,
Jim
Have a 2009 JK Sahara..
Tried taking the knob off. You need to remove bottom casing of knob, pry off rubber protection, pop off the head with a screw driver. Underneath the head is a metal casing which acts as a key. That needs to be popped off with a screwdriver as well. Once this is off, the rest of the knob should slide right off. The shaft is thicker than older models. I found that out the hard way and bought a knob that would fit an older model. Now I have to make the hole on this knob bigger.
Hope that helps
Old Jun 30, 2010 | 08:55 AM
  #35
plac's Avatar
Hope that helps
good to know.
Old Apr 18, 2011 | 06:23 PM
  #36
oppositemind's Avatar
For the record, I just whacked myself in the face and have a nice goose egg on my forehead...
Old Sep 30, 2011 | 01:41 PM
  #37
uup4it's Avatar
Sure enough, went to change out my shifter boot and used a wrench, hammer and towel wrapped around the base of the knob, 2 easy taps and the knob flew off into the back. EZ PZ
07 X
Old Dec 7, 2011 | 08:00 AM
  #38
trbizwiz's Avatar
does this work for 2011 and 2012.
Old Dec 7, 2011 | 10:20 AM
  #39
trbizwiz's Avatar
FYI it does work on the 2012 transfer case selector. Clip your fingernails. ( do this once a week, should have done it before I tried this modification). Shift the selector in to 4 low. Get a two handed grip, and summon some serious motivation. Giver her a good tug adn watch your teeth. I sliced my left middle finger open with my right thumb nail. I am clipping now. They arent long enough to extend past my finger tip or even close to it, but they are sharp mothers.
Anyway the shift selector poped right off, and right back on for that matter. I am addind seat heat, adn if you take the transfer case knob off you can remove the center console easier. that makes drilling the holes for the round toggle switch easier. FYI
Old Jan 21, 2012 | 09:25 AM
  #40
mjcjk2012's Avatar
Default removing manual shifter knob
does anyone know the trick to removing 6sp shifter knob on 2012
