replacing 3.21's
Old Jul 25, 2009 | 12:43 PM
ZoSo-Green's Avatar
Default replacing 3.21's
I did a quick search, and didn't find what I wanted.
What do I need to go from a 3.21 to a factory 4.10 on an '07 "X".
I have the the 4.10 D30 and D44 ring and pinion.
Do I need a carrier for the front ... or rear? Install kits? Be specific.
Please help, or guide me.
Old Jul 25, 2009 | 01:03 PM
bigbluejk's Avatar
you need the front carrier, or a front locker. how many miles are on your jeep? I would at least replace the pinion bearings myself. Get a overhaul kit from northridge4x4 and replace all the bearings while you are in. might as well.
Old Jul 25, 2009 | 04:14 PM
ZoSo-Green's Avatar
Originally Posted by bigbluejk
... Get a overhaul kit from northridge4x4 and replace all the bearings while you are in. might as well.
Thats the plan.
I just want to make sure I don't need anything other than the front carrier.
36k, - time to play!
Old Jul 25, 2009 | 04:19 PM
ZoSo-Green's Avatar
gears ... tires ... squishy springs ... trackbars ... ect...
I've waited two years for all this to happen!
Old Jul 25, 2009 | 04:27 PM
monte's Avatar
Either a front carrier OR a front locker, but not both? What about the rear?
Old Jul 25, 2009 | 04:35 PM
ZoSo-Green's Avatar
I am not doing lockers. What about the rear???
Old Jul 27, 2009 | 08:33 AM
Northridge4x4's Avatar
Sponsoring Vendor
The factory 4.10's should be a thick gear for the rear axle so you are good in the rear. I would get a new overhual kit for the rear though.
For the front you will need a Overhual kit and a Carrier.
David
