resetting TPMS
Old Feb 18, 2008 | 11:58 AM
Beancounter's Avatar
Default resetting TPMS
I just put my new wheels and tires on. Had new sensors put in them. They are now 315/75/16. My chime and light are still coming on.
I have read that others have gone to the dealer and had the TPMS reset. Any feedback on how this is done and what it should cost?
Old Feb 18, 2008 | 12:16 PM
Sotally Tober's Avatar
My dealer said they have to flash the computer to "learn" the new sensors. They said they would charge $35. When I had my new 35's mounted with new sensors Les Schwab said they could do it for $20. They are still sitting in the shop so I dont have first had experience.
Old Feb 18, 2008 | 12:32 PM
Jeep-N's Avatar
I just hade new sensors put in a set of Rubi wheels with BF mud tires. And didn;t have to get them reflashed. They work just as the stock sensors
Old Feb 18, 2008 | 12:33 PM
kntr's Avatar
I didnt have to get mine reflashed either. I bought aftermarket sensors too.
Did you put a sensor in the spare also? The computer reads it too.
Old Feb 18, 2008 | 12:36 PM
BaltChief's Avatar
I had my original sensors flashed so I could run 28 psi...they did it for free.
Old Feb 18, 2008 | 12:38 PM
I paid for sensors in all 5, but since they are not working how can you know their installed?
Old Feb 18, 2008 | 02:46 PM
rp41's Avatar
They shouldn't need flashed unless your running lower air pressures. Air them up 2-3 pounds over then drive it a few minutes. If the light goes out you can then lower the pressure to what it says in the manual or door.
Old Feb 18, 2008 | 03:25 PM
RevyJKU08's Avatar
You shouldn't have to reflash at all.
My guess one of the sensor's maybe hooped or one maybe damaged from them mounting your wheels.
Old Feb 18, 2008 | 03:40 PM
davidwm71's Avatar
From what I have heard the computer needs to know the serial numbers of the sensors in your 5 wheels... if not it would be picking up signals from every other vehicle out there with sensors. When I heard it I thought it made sense.
If you relocate your stock sensors and run the same pressure you shouldn't have to do anything.
Old Feb 18, 2008 | 03:48 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
I dont believe thats true about the serial numbers, Labrador is running the wheels/tires/sensors from my rubi on his sahara without any TPMS light ever coming on.
