Ripp Supercharger vs Hemi
We have 2 options for the 2011, one being our add on, fuel management. The other is a PCM swap to 2010 from RPM Extreme. With their ecu, you can enjoy all the tuning and calibration control that our 2007-2010 systems enjoy via Diablosport Predator. You can call us or them for more details on our options for your 2011 JK.
RIPPSALES
RIPPSALES
Can they be flashed with other tunes besides Diablo? IE; SuperChips
I've wrestled with these PCM swaps before on my 01 Dakota R/T. They rarely worked. JTEC is such a POS.
RIPPTECH
I had a supercharger on my 2011 which turned out to be a bad experience. It really did not provide the power where you need it. The Hemi should be going in soon. Just waiting on a few more parts. I wish I would have went straight to the Hemi rather than messing around with the 3.8. Just my opinion, I know that is not an option for most.
Originally Posted by RIPPMODS
We have clients on this Forum who have driven over 75000 miles on our system - Our kits are rather reserved and really don't look to blow things up. Jeep guys are not Vette guys - Meaning you aren't looking to go foot tot he floor and light to light racing. The RIPP kits perfect for transforming your 108WHP (on 35's) to a 200+ rear wheel HP vehicle, making it easy to drive...
With nearly 1000 kits sold world wide - we would say its proven its worth...
Xtreme 4X4 Video Hemi vs RIPP
Question welcome
RIPPTECH
Question welcome
RIPPTECH
RIPPTECH
Dave
Unfortunately I received a unit that had the wiring harness wired improperly and when I tried to start the motor the engine was flooded. The wiring was 180 out as far as the schematics was concerned. Rewired the harness to the proper orientation. Had to removed the dual batteries and spark plugs to blow out the gasoline from the cylinders. Reinstalled the harness and the motor did not start. Would not hit at all so sent the harness, module and fuel injectors back. Ended up having to do blow out the cylinders three times since I did not realize that the cooler and air duct was also full of gasoline. Finally got the harness, module and injectors back and installed. Still had a hard time starting even after leaving the cylinders open for a day.
The system was finally running and did well at first with power starting at 2500 rpm and really kicking in at 2700 rpm. Still had some down shifting of the transmission on steeper hills but manageable. Slowly the power lessened over the next 2500 miles till the transmission was down shifting as before to get up most of the hills and gas mileage had gone down to 11.5 mpg. Checked the boost valve to see if was operating properly with vacuum and found no issues. After talking with RIPP several times and really not getting anywhere close to figuring out what was wrong decided to remove the unit. Put everything back to stock and the gas mileage is back up to 13.5 to 14 mpg depending on my lead foot.
I really do not have a lot of time to be messing with something that is unreliable so I ordered the 5.7 hemi with a 545RFE transmission. Just waiting on a few more parts and it will be going in. If the torque and HP curve that is provided by the manufacture is correct then the Hemi should be providing plenty of low end torque and HP to run 35's with no issues.
This was a condensed version with not really all the issues, Just felt it would get to long if I went over everything.
