RK 2.5" X-Factor
RK 2.5" X-Factor
Have a question on installing my rear upper arms. Instructions from RK are not very clear. When measuring the beginning length do I need to measure from eye to eye on the inside of the bend or the outside of the bend?
When I did mine I measured straight end to end, right down the middle. The uppers were a little awkward with the bend. Plus it is a pain in the butt to tighten he jam nuts and keep the bend properly oriented.
You measure from the center of each hole. The bend in the arm dosnt change anything, its still hole to hole. It could bend to China and back and you still measure to each hole.
Actually it does. If you keep the moving part of the joint lined up inside the joint straight, then the holes on the inside of the bend are closer together then the holes on the outside of the bend. And that's measuring straight across. The picture below shows how they are on the jeep and what I'm talking about.
Maybe Rock Krawler will chime in on this, as there obviously will be a slightly different length depending on which side you measure. Out of curiosity, what is the difference in length? 1/2"-3/4"?
I'm not sure. I started kinda late yesterday and my wife was calling me constantly to come home and I forgot how they went on in the first place so I got so frustrated I just put it all back together and put all the RK stuff up for now until I can get to it. Wasn't happy bout it. But I want to know how it's supposed to be before I start on it again.
Not positive, but my MetalCloak arms do the same - if you have the joint turned the wrong way. On the adjustable end, there should be a bend where the threaded part meets the joint. If you rotate the joint half a turn, you should be good to go.
Pretty sure that's it. If not, I doubt those things will go in...
