Rock Krawler 3.5" X Factor vs Flex
Old May 1, 2015 | 06:49 AM
  #31
Invest2m4's Avatar
Originally Posted by DunnyBunny
There is someone on here that is running the RK 1.5" lift with flat fenders and 37s. It's not about lift height it's about proper bumpstops, proper length shocks, and enough clearance for the tires. Yes a 3.5" lift will allow him to run 37s but without the proper components mentioned already he will still have rubbing or other issues.
Someone runs 37s with no lift using the metalcloak fenders. Looks bad a##.
I had 14" of travel with 37s and 2.5" of lift. Required very minor trimming in the rear.
Old May 1, 2015 | 06:50 AM
  #32
Pyro1415's Avatar
Yes and he has no up travel only down. The point of a lift is to give up travel which is important. Plus I don't want to hit my bumps tops every pot hole. Your travel does stay the same total distance but it switches from down travel o up travel which is better for higher speed running. Plus if you run longer shocks to get that down travel without the the proper lift you can do damage. Unless you bump stop the hell out of it in which case it's a rough ride on you and your jeep and will look retarded without large tires. Finally up travel can help prevent you from rolling over as easily in some situations
Old May 1, 2015 | 06:56 AM
  #33
Invest2m4's Avatar
If you're going to use that much bump stop, you lose most of the value a lift can provide. I see it all the time, guy with x-factor lift, lots of bump stop, less travel than a stock a Jk. Better off running smaller tires and less bump stop.
Up and down doesn't really matter much when you have 7" of travel.
Old May 1, 2015 | 06:59 AM
  #34
Invest2m4's Avatar
And if longer shocks worked with the coils, everyone would run them.
Old May 1, 2015 | 07:05 AM
  #35
bob987909's Avatar
Thanks for the good info on here!
Last question, because the lift height won't be as much will upper control arms be necessary to run 37s? In some cases I know you have to trim the pinch seam with the larger tires and I am trying to avoid that.
Old May 1, 2015 | 07:08 AM
  #36
Invest2m4's Avatar
Originally Posted by bob987909
Thanks for the good info on here! Last question, because the lift height won't be as much will upper control arms be necessary to run 37s? In some cases I know you have to trim the pinch seam with the larger tires and I am trying to avoid that.
Front lowers should do it. Trim the pinch seam if needed. No reason not to. They actually come from the factory now with it trimmed. Won't hurt value or anything. Very easy to cut and then fill with JB Weld. You can get a little tune of the factory paint as well.
Old May 1, 2015 | 07:10 AM
  #37
Stubicon's Avatar
Originally Posted by Invest2m4
Ok, this is exactly my point. Explain to me how adding an inch of lift will help tire rub?
The shocks are the same. The axle can only droop to the point the shock is fully extended and compress to the point the shock is fully compressed. That is the linear line of travel (y axis). Where you sit on that line is determined by coils.
Let's say you have 10" of total travel. With a 2.5" coil you have 4" of up travel and 6" down. Then you get 3.5" coils. Now you have 5" up and 5" down. However, your tire still follows the same line of travel. If you rub now, you'll rub with more lift. To fix the rub you need to limit uptravel and that is done with bump stops. More lift does nothing.
Great explanation. This has helped me a lot in understanding the geometry of lifts.
Originally Posted by mds22
1" more lift allows for 1" more bumpstop +longer shocks = allow for bigger tires without rubbing, same up travel/ more down (longer shocks)
I may be looking at this incorrectly but if you add 1" more lift via taller springs and 1" more bumpstop you would negate the extra 1" you were trying to gain in uptravel correct? And longer shocks would just mean a longer shock body which would mean they would bottom out sooner at full compression again negating the extra 1". All you would gain is a little extra droop which I think is where you open up concerns for other components, ie. driveshaft, etc.
  #38
DunnyBunny's Avatar
JK-Forum Ambassador
Pinch seam can depend on backspacing of wheels, and width of tires, etc. I think you will be good with just front lowers and maybe rear uppers. Or even rear lowers. I think max travel should be ok for you.
I was referring more to the pinch seam in front for the wheel well, might not be an actual pinch seam. The rears come trimmed already on bottom with the newer years. As invest mentioned you can just trim it if not. It's not hard and had no negative effect
Old May 1, 2015 | 07:18 AM
  #39
bob987909's Avatar
Thanks for all your help!
Old May 1, 2015 | 09:25 AM
  #40
mds22's Avatar
This is true. However, a flawed solution. First off, shock body clearance will become an issue. Second, most coils won't extend enough. It's a mall crawlers solution to avoiding modifications to increase clearance for uptravel.
agree 100%. Just explaining their rationale better than they can and how i was convinced to get a 3.5. Yes I run a 3.5 and regret it with every unnecessary purchase due to issues I don't need to deal with. I'll repeat there is NO WAY I would go over 2.5" if I could do it over. But I'm already in too deep in my wallet to go back.
