Which Rough Country Lift??
![](https://www.jk-forum.com/forums/images/ranks/veteran_marine_corp.png)
3.5" Series II has been ordered and I'm getting the adjustable track bar as well. Now comes the painful waiting time
Is it here yet? I cant WAIT for spring and summer to go play again!!!!!
![naw](https://www.jk-forum.com/forums/images/smilies/icon_naw.gif)
I'm in Canukistan though. Gotta get shipped from the states to the shop I'm buying it through then out to me. I'm hoping for less than a week but it might be longer if it gets held up in customs.
Hoping too do his install tonight and I just want to clarify on the Pitman arm and track bar bracket. Am I reusing the stock ones or removing completely?
I would also suggest swapping out the 14mm stock trackbar bolts for grade 8, 3" long, fine thread, 9/16" bolts. Use either a stover locknut or a split lock washer on the back side and a grade 8 flat washer on the bolt head side.
https://www.jk-forum.com/forums/show...es-and-Wobbles
Also! When installing the lift. Do NOT tighten the control arms or trackbar until the jeep is sitting on all 4 wheels (so not on jack stands). Shake the jeep back and forth to settle everything, Then tighten the trackbar and control arm bolts
