Rubbing on full flex
Old Sep 24, 2013 | 04:52 PM
Scruff's Avatar
Default Rubbing on full flex
Hi all
Just went to 37s on my 2 door jk and there is some slight rubbing on the body on full flex
I don't really want to increase my lift height again as I want a low cog.
In your opinion is minor rubbing ok?
Cheers
Old Sep 24, 2013 | 05:08 PM
TheDirtman's Avatar
you can increase your bump stop. Any photos of where it is rubbing?
Old Sep 24, 2013 | 05:10 PM
Scruff's Avatar
No photos yet as it is at the shop at the moment. I have increased the bump stop an inch already.
Im trying to run 37s with a 2 inch lift so cant bump stop too much.
Old Sep 24, 2013 | 05:13 PM
TheDirtman's Avatar
Whats your wheel back spacing? any spacers? Pushing the wheels out will prevent rubbing on the steer wheels.
Old Sep 24, 2013 | 05:17 PM
Scruff's Avatar
Yeah its 4.75 backspaced with a 0.75 coil spacer also.
Scruff's Avatar
Would u be concerned about a bit of rub?
Old Sep 24, 2013 | 05:19 PM
TheDirtman's Avatar
Thats your problem, not enough wheel bs. You should be around 3.5" with 37's on that little of lift.
Old Sep 24, 2013 | 05:21 PM
Scruff's Avatar
So new rims it is.
Thanks
Scruff's Avatar
By the way awesome build thread
Old Sep 24, 2013 | 05:22 PM
TheDirtman's Avatar
As long as it was not rubbing on anything sharp and you have clearance on the sway bar links. I ran one thru a 37" tire once when running 4.63" bs wheels. I added 1.5" wheel spacers after that. For clarification I was running a 12" travel shock at that time.
