Rubbing on full flex
Old Sep 24, 2013 | 05:22 PM
nthinuf's Avatar
edit - Sorry, I misread it. I was thinking it was a .75" wheel spacer not a coil spacer.
Old Sep 24, 2013 | 05:24 PM
Scruff's Avatar
If I ditch the spacer ill probably change spring to a 2.5 inch.
If I got higher then ill need to do arms etc wont I?
Old Sep 24, 2013 | 06:04 PM
Ncb's Avatar
Ncb
More lift wont fix the rubbing. Something has to limit the up travel.
Old Sep 24, 2013 | 06:09 PM
Scruff's Avatar
So back to wheel spacer or new rims
Old Sep 25, 2013 | 01:11 AM
Mark Doiron's Avatar
It would be best to know where it is rubbing before hazarding a guess as to how to stop it, or whether you can live with it as is.
Old Sep 25, 2013 | 01:14 AM
Scruff's Avatar
So it is rubbing on the frame inside the wheel arch
Old Sep 25, 2013 | 04:55 AM
familytime's Avatar
JK Forum Regional Rep
Not to change the thread,but how not having more lift not fix the rubbing problem Bump stops will control up travel
Old Sep 25, 2013 | 05:24 AM
Front wheels just when turning? Maybe you could limit steering wheel turning radius. Here's the procedure if you think that might help ...
wayalife.com/showthread.php?4091-TECH-TIP-Jeep-JK-Wrangler-Steer-Stop-Adjustment
Old Sep 25, 2013 | 05:29 AM
... there is some slight rubbing on the body on full flex ...
Actually, in hindsight I'm trying to reconcile these with what I wrote just above. I asked about turning, but perhaps turning has nothing to do with it. Which leaves me puzzled about exactly where the rubbing is if the tire is contacting the frame--you didn't specify which axle, for example. Hate to be a nitpicker, but you'll get better answers the more complete info you provide--a picture would be great, too.
Old Sep 25, 2013 | 05:33 AM
In general, it would depend on where the rubbing is. If it's fender rub, more lift would help. If it's rubbing on the sway bar links, maybe not. Rear axle could be rubbing on the pinch seam, and more lift may or may not help--depends on how much lift and particular tire size. In this case "on the frame" suggests that the tires are too close in to the frame rails. A little less backspacing will push the tires out from those frame rails. Or, if it's just when turning hard, he can adjust the steering turning radius.
