Rumble when accelerating. Could it be pinon angles?
Going to take her by a transmission shop tomorrow to see what they say. I feel like it could be so many things, I'll probably go to multiple shops and see what they all say.
My mechanic deducted it was the torque converter. There was a recall on the TC from 2007-2010. I am thinking some of our 2011s got the bad TCs as well. Mine has been fine ever since. "knock on wood".
Turn O/D off seems to help a little bit but I can still get it to happen when accelerating.
The shudder is a bit picky. I can only get it to happen when traveling below 10mph and go to accelerate quickly.
From a dead stop on flat I can't get it to reproduce. If there's a bit of an incline then it pops back up. But that's not to say the incline is the only top. It's happened once turning right at a light going downhill.
If I let off the gas slightly it stops rumbling stops.
Someone somewhere mentioned that maybe it's a bad misfire issue. The Jeep definitely doesn't sound the best on a cold start, and does have a slow engine oil leak.
Just an FYI for you and anyone else that may stumble upon this thread.
I had a 2014 JKU and now a 2015 JKU, both had a 3" BDS lift done by the dealer and both Jeeps had this same problem. It happens at slower speeds when I am around 1600-1800 RPm's, it just sounds like a heat shield or something vibrating. I have factory warranty but have just been to lazy to deal with taking it to the dealership and being a couple of days with no car. I have crawled all over the under side and can't find the problem. And I can only some times get it to make the noise while sitting still in drive and getting the RPM's up in that noise range.
