Run 37" tire with Front D30 ?! possible ?!
I know it's not the best solution to run 37 with D30 , but is it concevable to run 37 with a front D30 with somes specifics mods ??
If I go this way ,I know I should upgrade to chromoly shaft, and what else I should upgrade to be enable to do trail/rock occasionally(daily driver), I don't used to do extrem rock crawling.
Please let me know which part I sould also upgrade in my situation.
For your information, before to tun 37 (now running 35), I would regear to 4.88 or 4.56, is 4.56 to fast for 37 ? ...and 4.88 to slow for 35 ?! I have a manual unl. 2011 still with 3.73 for moment !
throwem on and call it a day.. people have done worse... id go at least 4.88 if not 5.13. ring gear will be weaker but other than that its basically a d44. even with slight off roading id at least be prepared for a break possbily. that being said its still up for debates if id even be comfortable running 37s on my d44... im still testing that until my tires wear down more.
If I were you I would be 100% prepared to break on any 4x4 outing!! Bring warm enough gear to spend the night on the trail. If you were to tell me it never sees off road,, I'd say go for it; but for off road,, I wouldn't risk a major break do to a ridiculously weak driveline. Just my 2 cents,, sorry,, but good luck.
YA OK. 3 YRS so far on 38.5 pitbulls no problems yet. people talk b/s and have no real world experience.
they just hear people say I wont do it. people that break and bend them are jumping rocks or hitting to hard trying to climb. take it slow and you will be fine. do c gussets and do truss or sleeves
rausch creek pa has not damaged my d30 yet. if it does then ill upgrade
rausch creek pa has not damaged my d30 yet. if it does then ill upgradeAttachment 527676
I'm running 37's on my D30 without any hitches so far. I don't do any hard wheeling, but trails and a little bump stuff. The occasional crawl. I just try to take it easy. I'm not going to be bouncing my shit on boulders like you see these guys doing with their D60 equipped rigs.
Running 37" mtr/k on d30. D30 has RCVs, evo sleeves, 4.88 and ARB. Not saying that it won't blow up, but hasn't yet. Not doing KOH runs, but do wheel moderate
Add a couple more "poser" shots for ya
also matters on the d30 being locked or not. we have one guy running a d30 and he blew 3 different spyder gears in the last month or 2 alone with his being open. He is on 35s and wheels pretty easily on it out here...
