Running 35s but towing a Camper?? Need some Obi-wan advice
Old Sep 7, 2012 | 05:15 PM
Ryan0260's Avatar
Originally Posted by EVO MFG
Gears!
5.13's if your not wheeling, 4.88's if your wheeling it.
He's talking about the fact that the pinion gear is tiny on a D30, and wheeling puts a ton of stress on it. 5.13's have more teeth and are finer, and therefore won't be as durable as 4.88's
skibovr6's Avatar
I have a 6 speed and thought I would be ok with 373s guess not
Old Sep 7, 2012 | 07:44 PM
castor07jk's Avatar
We use to say the same thing about 4.56s in D44 20yrs ago.
The 5.13 pinion is smaller and has fewer teeth. Which means less contact surface( fewer teeth engaged) with the ring gear.
In all actuality +90% of the members here don't wheel hard enough for that to come into play. Not everyone wants to climb a 3ft-4ft under cut ledge.
Old Sep 7, 2012 | 08:35 PM
Phunkeydude's Avatar
Love your setup skibovr. Looks great!
My setup:
AEV 2.5" w/ 35" Maxxis Bighorn on 17x9.
Auto 5spd w/ 3.73 on 3.6L Pentastar but plan to re-gear to 4.56 to keep my Daily Driver in the sweet spot and because I haul a camper and hit the trails once in a while. Lost a little pep w/ 35s but livable for now. Towing 3500lbs up Wolf Creek Pass CO is a tad ruff.
ID:	363416   Click image for larger version
ID:	363417   Click image for larger version
Old Sep 7, 2012 | 09:36 PM
EVO MFG's Avatar
Sponsoring Manufacturer
Originally Posted by castor07jk
You got that backwards.
4.88s if your NOT going to wheel it. 5.13s if you ARE going to wheel it.
He has a Dana 30 front, smaller ring gear. I wouldn't run 5.13's if he plans on wheeling it
Old Sep 7, 2012 | 09:40 PM
EVO MFG's Avatar
My setup:
He's doesn't have a penstar. He'll need more gear...
Old Sep 8, 2012 | 08:10 AM
Ryan0260's Avatar
The 5.13 ring gear has 2 more teeth than a 4.88 ring gear, therefore it has more teeth, which means less surface to contact the pinion gear. Less material to contact the pinion gear is what makes them weaker
Old Sep 8, 2012 | 08:56 AM
castor07jk's Avatar
I stand corrected on the tooth count.
4.88 39-8
5.13 41-8
Old Sep 11, 2012 | 01:24 PM
KSRubicon's Avatar
Gears!
Other way around....
5.13 if wheeling....4.88 if not....
And with the Pentastar and Expedition style Jeep (with trailer) on 35s:
4.88 if you're wheeling, 4.56 for more highway mpg and still a huge bump in torque over 3.73.
Old Sep 11, 2012 | 03:34 PM
EVO MFG's Avatar
If he wants the jeep with the best performance on the road he needs to run 5.13's. If he's wheeling he should go with the 4.88's to get a little stronger R&P. This is my Opinion, I would never gear based on MPG, if I cared about that I would have bought a VW turbo diesel
