Rythmatic Vibrations on a 2DR!
The vibe seems to stay the same once I hit speed. One last thing before I start, all I need to do is remove the 8-8mm bolts and the 4-15mm bolts correct? Leave the flanges and all other bolts alone? Also do I need to out the Jeep on jack stands or can I do it while all four tires on the ground?
I really want to know what is going on with his rig, the suspense is killing me. Front DS deffinitely has to be ruled out, but I think the rear pinion angle is just too fubared.
If it's not the front, then yeah, most likely the rear and it may have been on the way out anyway. If it's the rear, he'll need to get rear uppers as you stated and might aswell go aftermarket shaft while doing so because that rear isn't gonna last long especially if it's vibing already. I was just eliminating all the cheaper fixes first.
Probably no help, but.
If I run my stock BFG MTR's over about 3500 miles without rotating, I will start to get slight vibes in the steering between 50-55 mph or so. 8k or so after a balancing they will do the same thing.
Ok I got all the bolts off the driveshaft, but how do I actually release it or pull it out??
Tap the pinion end with a hammer,it'll fall off , tap the tfcase end with a hammer, it'll get a little gap in the tfcase end where it seats and stick a screwdriver in the gap and work it out.
