SC, avoiding the pinging before install
Old Sep 19, 2010 | 10:24 AM
JKSBISLANDER's Avatar
Question SC, avoiding the pinging before install
I have searched a lot and it seems the common cure for these pinging issues is to run your JK on the "tow tune" with 91 or higher octance, is this a wise choice? or should I still try a performance tune and see what happens?
also if I am too add a intake after this tune should I re-tune so the PCM re-learns again with the add on?
Thanks for the help!
Old Sep 19, 2010 | 10:29 AM
greasyspider's Avatar
I installed a superchip 2 weeks ago and don't have any pinging.
Old Sep 19, 2010 | 11:42 AM
4play's Avatar
No pinging for us on the 87 performance tune
Old Sep 19, 2010 | 11:59 AM
alright sounds good, I will install the basic 87 performance tune and if all is well then so be it
Old Sep 19, 2010 | 12:15 PM
Dronac's Avatar
Regardless of your tune level, moving up one grade (unless your running the 93 tune, in which case you would need an octane booster) should take care of pinging.
