Shaking after leveling kit??
When I took my Jeep in for my alignment after getting my 3.5" lift on, the alignment specialist told me he could not change the toe because it is a straight axle and I needed different ball joints? Everything I have read about changing the toe said to do it after install like it was no big deal... Did I take it to a bad shop or do I really need to buy another part to be able to set the toe in?
I didnt change wheels and tires.
I followed the instructions which said to do it in the air not on the ground.
After feeling the shaking for 2 days, I took everything off and redid it to make sure nothing was messed up.
I'm going to get it aligned in a few days.
Itisa constant shake that gets very bad when I hit bumps. I have only gotten death wobble once.
I had the same problem.common mistake of tithing everything of the ground.i loosen everything n retighten,now is good no more bad shakes.im still going to get an alightment since I ordered new wheels n don't want to find out the hard way that I could have use one.
I jacked it up and checked the tires, they are on there very firmly, no spacing or blockage. I'm going back to my friends house who has the torque wrench and I'll jack it up and loosen the bolts and redo it on the ground. I'll keep yall updated. Thanks everyone
