Shaking after leveling kit??
DW is not a side effect of anything. it is typically caused from loose, worn out or failing suspension and/or steering components. so long as you install everything correctly and make sure that you components are in good shape, you will not have DW.
Originally Posted by DesolationMania
I have the Teraflex BB and have yet to get a death wobble. But what I do have is a thud in the rear that for the life of me cannot figure out. But Ive never heard of DW with this kit.
Awesome. Thanks much!
Update: checked wheels and tires, they're on good and tight. I jacked up my baby and loosened the bolts, I then lowered it to the ground so it was on it's own weight, then I retightened the bolts. I took it for a test drive, and it feels a little more stable. Do I need to do the shock bolts also? Or just the sway bar? I'm taking it to get the wheels balanced and to get an alignment tomorrow. I'll update after.
it has stopped shaking. Thanks for all yalls help
