Shock extenderes on BB
Old Jan 28, 2015 | 06:57 AM
jadmt's Avatar
JK-Forum Ambassador
Originally Posted by TheDirtman
Shock extension will work fine but he does not need to run a lift at all to run 33's on a mall crawler. If he wants the look of a lift and keep the factory ride, trimmed or flat fenders is the route to go otherwise I would not go over a 3/4"-1" spacer and no shock extensions would be needed.
will running shock extensions have any negative effect on articulation? Not sure why I am having a hard time with wrapping my head around it but seems like it would give more down travel but less up travel, is this correct or am I looking at it wrong. Would adding say a 1" extension turn a shock that normally has a extended length of say 24" and a collapsed length of 15" into essentially a 25" and 16" shock? thanks
Old Jan 28, 2015 | 08:04 AM
immortalmetal's Avatar
If its a mall Crawler (nothing wring with that) then it shouldn't matter. He's not flexing it or beating on it on the trails, then just get a bb and be don't with it. Or like other guy said, get a 1" and. 75" spring spacer puck and be don't with it
Old Jan 28, 2015 | 10:12 AM
TheNoob's Avatar
Jadmt : I'm running a 2.5" TF BB with the shock extensions and I have decent amount of up travel. My 35s tuck well into the fenders. In my case they don't limit the up travel, the bump stops do.
Old Jan 28, 2015 | 11:04 AM
TheDirtman's Avatar
Shock extensions should not do anything to change your overall articulation or travel. You are right on your measurements and you should also add as much extra bump stop as you do with the extensions so you don't bottom out the shocks.
