Shocks
question, I have a stock 2008 Sahara I just picked up. Unfortunately, do to "spousal constraints", I am very limited to customization until sometime after intial purchase. Although the stance is ok as is, I would like to get the body off the tires a little more. Short of a full on lift which I cannot sell at this point, will shocks give a lift unitl a full lift can do at a later date? I have heard some shocks can boost anywhere from 1-3"....true?
They are not the most inexpensive solution though.
If you are ok with the stance, but want to get the body off of the tires more, that's EXACTLY what a Body Lift is for....it also makes room for LARGER tires.
A simple spacer lift is also an option, and can be combined with the BL with no problems, and in any order.
Your next mod will need to be a set of balls though.
