Shocks
Old Mar 13, 2010 | 03:31 PM
TEEJ's Avatar
Talking
Originally Posted by Bama-Batman
question, I have a stock 2008 Sahara I just picked up. Unfortunately, do to "spousal constraints", I am very limited to customization until sometime after intial purchase. Although the stance is ok as is, I would like to get the body off the tires a little more. Short of a full on lift which I cannot sell at this point, will shocks give a lift unitl a full lift can do at a later date? I have heard some shocks can boost anywhere from 1-3"....true?
The shocks you refer to are designed with a coil rest, so that they can provide the lift you describe.
They are not the most inexpensive solution though.
If you are ok with the stance, but want to get the body off of the tires more, that's EXACTLY what a Body Lift is for....it also makes room for LARGER tires.
A simple spacer lift is also an option, and can be combined with the BL with no problems, and in any order.
Your next mod will need to be a set of balls though.
