Shocks too stiff!
Old Apr 20, 2018 | 11:45 AM
mark@markpicard.com's Avatar
Default Shocks too stiff!
I own a '14 Jeep Willys edition, 2 door, with a Rough Country 3.5" lift kit with 35" tires on Fuel 17" aluminum wheels and I don't use this vehicle for any severe use such as rock crawling or heavy trail use. I primarily am on either paved roads (to get to the trail stuff) or old logging roads up here in Northern Maine. While driving on paved roads I find the ride to be VERY stiff. I have the Rough Country shocks which came with the kit. Can anyone recommend a better riding shock? Perhaps an adjustable shock? I really don't want to break the bank on this if possible. Thanks for your advice!
Old Apr 20, 2018 | 11:47 AM
BoraBora's Avatar
Rancho 9000XL's fit the bill. The adjustability is very very noticeable, and they rode great when I had them.
Old Apr 20, 2018 | 12:05 PM
resharp001's Avatar
Loved
Community Favorite
^^+1. The Ranchos are the most budget friendly easily adjustable shock out there that would probably suit you well.
Old Apr 20, 2018 | 12:51 PM
ldstruckn's Avatar
Vet Army
i also recommend the rancho 9000's. as you upgrade the jeep you can easily soften or stiffen the shocks to accommodate weight or street trail use.
Old Apr 20, 2018 | 01:32 PM
nthinuf's Avatar
What psi, and what is the load rate on the tires.
Rancho runs a lot of promotions, ( 4 for the price of 3, or gift cards of various amounts), so be sure and check for the mail-in rebates. Last I heard they also had a try-for-90-days and if you don't like them, return them, on the 9000's. You might also read through a few of the threads on these shocks for some feedback on the adjustment knobs.
Old Apr 20, 2018 | 03:22 PM
TheDirtman's Avatar
RC shocks run on the soft side. I would check your tires first to see what you are running and at what psi. A "C' rated tire is plenty for a jeep and will offer a better ride then The heavy duty "E" rated tires many jeepers make the mistake of installing. Northern Main, you may also want to find shocks that run thinner oil to compensate for the cold. RK says you should expect their shocks to run rough if the temp is below 50 and you should change to a thinner oil.
Old Apr 22, 2018 | 11:48 PM
PET77's Avatar
Could very well be the spring rate too. Most aftermarket springs are "tuned" for heavy rigs (armor, steel bumpers, winch, etc.), so if you have a stocker, they:1) will net more than expected lift, 2) wont really want to compress under normal driving conditions... Donīt know about RC, but Eibach have near stock spring rate.
Old Apr 23, 2018 | 10:32 AM
Rancho's Avatar
Sponsoring Manufacturer
We re on rebate right now.
If you buy online save the UPC codes.
Promotions
