Shortest 3" lift system?
I know, what do you mean shortest? most people want to go bigger. Ive been down that road several times. 35's will be plenty for what I do. and if not, some new higher clearance fenders and a 1" body lift are cheap enough to shoe horn 37's or 38's in on down that endless modifying road.
Since real world numbers go out the door when the amount of lift is stamped on the systems box cause of all the variables like 2 door or 4 door, HD or MD springs.
I was wondering if the masses on here have a consensus on which manufactures 3" lift system. And when I say system I mean complete with track bars or quality relocation brackets, control arms brake lines, coils etc... Is the shortest 3" for a 2 door JK.
I figure some of you guys and gals have probably wheeled and parked next to each other and have friends that have different systems than you.
I want quality. So this 3" system would need to come from a reputable manufacture like Teraflex, Currie, Clayton, Full traction, Superlift etc..
Thanks for your input.
from what I have seen I think BDS looks to be the shortest and Teraflex seems to be the tallest. BDS is a great suspension and they have lifetime warranty on parts. Price is right to Personally I am going Tera 3"
I have the BDS 3" lift. I put on an adjustable front trackbar and used their rear drop braket in the back. The drop brackets (for the trackbars) that come with the kit mount to the frame, instead of to the axle where many have experienced issues of breaking the factory weld. The BDS 3" lift I think is the shortest 3" kit. I gained EXACTLY 3" with the kit. Most companies go over 3" even though that is the advertised height. If you don't want more than 3", I would say the BDS kit is the way to go. Given the fact that you only get 3" and no more, it also helps the life expectancy of your driveshafts. I have been running my stock driveshafts now for about 10K miles since the lift was installed.
I have added a 1" BL, and if I go to 37's, I can swap springs to the BDS 4" springs down the road.
I want a complete system with at least a front track bar and control arms and brake lines. Not really wanting to piece a kit together to make a complete system.
Thanks for the reply
you know everyone will just reccomend the lift they have. I like my tera 3"... but it gave me like 5" front and 4.25 rear I think. It is big. How is your budget? You could get a teraflex flex arm set, and OME LT shocks and HD springs. That would give you 3". Add some adj. track arms, extended brake lines and bumpstops, and some coil retainers and extended links. Call it done. Seems like it would be expensive that way. lol.
Maybe if you really like teraflex you could get them to sell you the 3" system with the flex arms and adj. track arms. but swap out the springs for the ones from the 2.5" kit. That would give you 3" oflift. but also be a full system.
I don't mind a bit more than 3". But I don't want upwards of 5" in front like I keep hearing with some systems out there. My reasoning is more in line with keeping a lower center of gravity and not having to piece meal a kit with other parts to make it complete. I plan on replacing my drive shafts when I install the lift.
