Shredded threads
How old is it? A new AC Delco professional end (pretty much the OEM at a lower price) is only about $20 and if you think you can unscrew it out of the adjusting sleeve it would be a lot easier than trying to re-thread. If you are only running the OEM, I'd look at that first. Someone with some more experience in re-threading may be able to comment more about if that's fixable. I would say if you match the thread pitch and count you would know if its re-usable or not but if it were mine I would want the new end if possible.
In my opinion it's way better to go get a new one because threading this will require you to remove the threads and make the hole thing smaller in diameter then thread it again and buying a nut to work with it but in reality it's risky cause you have now a smaller bolt " and sanding it down and removing the threads will take forever cause you're not going to disassemble the joint and remove the threads on a lathe the best thing to do is get a new tierod
