Shredded threads
Old Nov 1, 2019 | 11:36 AM
kwhit83's Avatar
Default Shredded threads
Any quick fix to shredded threads on a oem tie rod end? Passenger side
Old Nov 1, 2019 | 12:18 PM
EHarris's Avatar
JK-Forum Ambassador
How old is it? A new AC Delco professional end (pretty much the OEM at a lower price) is only about $20 and if you think you can unscrew it out of the adjusting sleeve it would be a lot easier than trying to re-thread. If you are only running the OEM, I'd look at that first. Someone with some more experience in re-threading may be able to comment more about if that's fixable. I would say if you match the thread pitch and count you would know if its re-usable or not but if it were mine I would want the new end if possible.
Old Nov 1, 2019 | 12:27 PM
G.A.H's Avatar
In my opinion it's way better to go get a new one because threading this will require you to remove the threads and make the hole thing smaller in diameter then thread it again and buying a nut to work with it but in reality it's risky cause you have now a smaller bolt " and sanding it down and removing the threads will take forever cause you're not going to disassemble the joint and remove the threads on a lathe the best thing to do is get a new tierod
Old Nov 1, 2019 | 12:55 PM
bkg's Avatar
bkg
tie rods are consumables... throw that away.
kwhit83's Avatar
It’s a ‘13 Jeep...pretty sure it the original. Also I believe on the passenger side it is pressed in so there’s not a way to unthread it.
Old Nov 1, 2019 | 12:57 PM
bkg's Avatar
bkg
don't care if it's a 2021 Jeep. TRE's are consumables. Replace that thing.
Old Nov 1, 2019 | 01:01 PM
G.A.H's Avatar
Yup true the only thing you can do is replace it
Old Nov 1, 2019 | 01:10 PM
kwhit83's Avatar
it looks to be crimped In.....tried everything i knew to get it out and it never budged.....looks like i have to replace the whole TR..
Old Nov 1, 2019 | 01:34 PM
G.A.H's Avatar
It's better to replace the hole thing but you can still buy only the outer tierod end alone
Old Nov 1, 2019 | 03:07 PM
resharp001's Avatar
Loved
Community Favorite
I don't know why nobody has mentioned it yet, but you should just go ahead and replace that.
