Side rail/step recommendations....
Old May 21, 2014 | 04:57 PM
  #21
trouty33's Avatar
Originally Posted by The Black Jeep
I put on the e auto grilles from eBay I know there are haters but they fit perfectly look great and I just got back from moab and drug then on numerous rocks they held up better than my fuel tank skid can't beat the price 260 ish shipped <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=554564"/>
They look like what I am looking for. Just went looking for them and can't find them, looking for more info. How do they attach?
Old May 21, 2014 | 05:30 PM
  #22
janders82's Avatar
i think i found them
http://bit.ly/1hiY1O6
Old May 21, 2014 | 05:52 PM
  #23
The Black Jeep's Avatar
Originally Posted by Sirb
Looks good, BlackJeep. Do these install to the body mounts like the Ace bolt-ons?
they bolt on the bottom of the body mount bolts yup took about 10 minutes to install both
Originally Posted by Roryslife
Those look exactly the same as Smittybilt SRCs.
they seem to be exactly the same as the smittybilt ones I have seen them side by side im sure they were built in the same factory or at least the same specs
OP... as the most qualified person here to answer your question (I'm 5'4").
If not wheeling, then the smittybilt SRC or their duplicates in the quote above from ebay are the best cost effective sliders. I think they look pretty awesome as well.... but....
They suck if you are going to play on rocks. They only have two support legs, so they would get pushed in in the middle on impacts. Note, this only happened if banging your jeep around like I did.
As steps though, they are awesome... lots of platform to stand on.
ID:	554686Click image for larger version
I strongly disagree with the above post I just got back from moab and I set my jkur on theses rails numerous times only scratches in the powder coat easily fixed with rustoleum bed liner the same rocks dented and trashed my factory fuel tank skid no dents at all in my rock rails also the 2 door model has only 2 mounts the jkus have 3 mounts
they attach on the underside of the body mounts 2 bolts
here is a link
07 14 Jeep JK Wrangler Tubular Step Armor Rock Slider Rocker Guard Nerf Bar | eBay
ps I have only found the e autogrilles for the jkus not for the 2 doors so far anyway but it looks like yours is an unlimited
Old May 21, 2014 | 07:02 PM
  #24
Roryslife's Avatar
Attachment 554686Attachment 554689
here is a link
I was fooled just like you, but it will happen. Mine gone pushed in so far that they started rattling against the lower body panel. Couldn't figure it out at first because the sound traveled up the b-pillar and completely fooled me as to where the sound was coming from.
To be fair, I wheel pretty hard, and here in Idaho we have canyons and trails that are basically boulder fields, and the SRC style hung to low and just didn't give enough clearance.
I ended up selling them and replacing them with LOD sliders that I had welded on. Much more sturdy.
Old way
Name:	Photo Jul 04, 1 08 53 PM (Large).jpg
What it couldn't do
But... for the OP, I think the SRC / e-grills style is the way to go.
Old May 21, 2014 | 08:29 PM
  #25
RoccoV's Avatar
So check out these. I bought them for the same reason.
Manufacturers of high quality Nerf Steps, Prerunners, Harley Bars, Light Bars, Replacement Front Bumpers, Rock Rails, Rear Runners, Tire Carriers & Truck Accessories
Love them!!! Check my profile for more pics.
Old May 22, 2014 | 01:30 AM
  #26
trouty33's Avatar
Thanks Black Jeep. Exactly the info I'm looking for!!!
Old May 22, 2014 | 06:43 AM
  #27
JK-USMarine's Avatar
The Black Jeep and I are wheeling buddies and he has the JKUR with the eBay rails and I have the JKR with the Smittybilt rails. There are a couple of small differences but essentially they are the same. We both wheeled pretty hard in Moab about a month ago and the only damage I received from setting down on them pretty hard and sliding on them was a couple of scratches and shallow flat spots that as he said could be easily "repaired or hidden" with bed liner. All in all I think they both are pretty good. It just depends on how much you use them, how you use them and potentially where you use them to help determine what you get, IMHO. The guy from Idaho apparently uses his differently than we do.
Old May 22, 2014 | 04:20 PM
  #28
cdenny's Avatar
LoD's have a step and are bolted several times into the frame
Old May 22, 2014 | 04:40 PM
  #29
trouty33's Avatar
Thanks!! I won't use them that hard I'm sure of it. If you guys got them through Moab I'll be fine here with them. Thanks again for your input and Semper Fi
Old May 22, 2014 | 05:32 PM
  #30
twofourflinching's Avatar
Originally Posted by cdenny
LoD's have a step and are bolted several times into the frame <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=554880"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=554881"/>
can you run stock rubi rails with lod
