Skid Plates
Old Nov 11, 2009 | 02:39 PM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by RedneckJeep
Not to mention all that extra WEIGHT. "Pretty pricey but its sick looking" Skid plates for looks? You gotta be kiddin me. The only additions I can think would be good would be for the oil pan as Eddie said and the evap canister if you don't relocate it.
right, the EVAP skid isn't such a bad idea. i used to be a big fan of relocating it and would still be if it weren't for california emissions laws and the fact that they do visual inspections.
Old Nov 11, 2009 | 02:46 PM
Piginajeep's Avatar
IMO replacing the stock transmission cross member is a good idea at some point,. the stockers is not very strong at all
Old Nov 11, 2009 | 02:54 PM
wayoflife's Avatar
JK-Forum Founder
yeah, it can get beat up pretty good but more than the cross member, it's mounts to the frame rails are what i would really be concerned with. i have already had to weld up good size cracks in the flanges twice - once before installing a long arm kit and once after replacing the cross member with the one that comes with the full traction long arm kit. i should note that while the new full traction cross member is super beefy, it's almost too much so and without any reinforcment to the frame rail mounts, it'll take a beating but will still get torn off. BTW, i have since welded on gussets to help support the mounts.
Old Nov 11, 2009 | 03:01 PM
Piginajeep's Avatar
maybe they need to make a new mounting flanges to go along with the cross member. I have yet to have the flanges crack, but I dont wheel as often or hard as you guys in socal. Hard enough to destroy the stocker cross member however.
I just cant imagine having a long arm kit that uses the stock cross member as support.:
Old Nov 11, 2009 | 03:17 PM
RedneckJeep's Avatar
Who make san aftermarket one?
Old Nov 11, 2009 | 03:23 PM
Piginajeep's Avatar
fulltraction does, but i'm not sure when they'll be available seperate from the long arm kit
Old Nov 11, 2009 | 04:06 PM
PoorDad's Avatar
Kilby makes skids.
kilbyenterprises.com
Last edited by Piginajeep; Nov 11, 2009 at 04:06 PM. Reason: please dont post clickable links to non-sponsors
Old Nov 11, 2009 | 04:22 PM
seer1's Avatar
i talk to one of the guys at sema who had it installed on his jk and was told that nothing bolted right up. he said that the holes didn't line up and that he had to ream several of them out to make it work. just thought you should know.
My RR's bolted straight up. No problems. Actually were an easier install than the Rock Hards I used to have.
Definitely wanted more protection for the Atlas.
I think the skids the OP is talking about are the Treks with the boat sliders.
Old Nov 12, 2009 | 05:37 AM
1dirtracer's Avatar
do these tranny skid plates replace the stock tranny plate
Old Nov 12, 2009 | 05:41 AM
wayoflife's Avatar
JK-Forum Founder
he's refering to the t-case skid and not tranny. he has an atlas t-case and you cannot use the factory skid with it as it is so big. most people with an atlas just leave the skid off but, i could see wanting a skid here and this would be an instance where an aftermarket skid is a good idea.
