Slider decision.. Rockhard or VKS?
Old 11-19-2015, 05:54 PM
twofourflinching's Avatar
Default Slider decision.. Rockhard or VKS?
Torn between the two. Pricing on both are similar, Vks comes bare metal so would need to powdercoat. What would you choose?
Vks
Hardrock
Old 11-20-2015, 03:42 AM
JE8154's Avatar
VKS, frame welded vs rock hard, body mount bolted.
Old 11-20-2015, 03:48 AM
WHT_JKUR's Avatar
Originally Posted by twofourflinching
Torn between the two. Pricing on both are similar, Vks comes bare metal so would need to powdercoat. What would you choose? Vks <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=630615"/> Hardrock <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=630616"/>
Have not seen the VKS before... I really like the look!
Old 11-20-2015, 04:23 AM
Maertz's Avatar
Vks is a lot more common on another forum.
Old 11-20-2015, 04:27 AM
BigPrince's Avatar
VKS or EVO all the way.
Old 11-20-2015, 05:08 AM
jadmt's Avatar
Those were two that were in my top choices but I ended up going with LoD sliders and happy as a clam. I like that they come powder coated and the powder coating has held up very well.
Old 11-20-2015, 05:11 AM
SH0RTBUS's Avatar
Between those two, VKS all the way. Welded on vs. bolt on makes a difference. When I'm ready, my set will be custom built weld-ons. Just gotta' drop it off and hand over $600.
Old 11-20-2015, 05:53 AM
sea bass's Avatar
I went the VKS route. I almost hated to powder coat over them beautiful welds!
Old 11-20-2015, 07:12 AM
Invest2m4's Avatar
I like the new VKS Prerunner sliders. Frame mounted, but bolts so you don't have to weld. Just as solid as welding. I weld everything on my Jeep, except my sliders. I've had to remove them for various reasons a good 5 times now. I'd hate to have to cut them off every time.
Prerunner Rock Sliders - VKS FabricationVKS Fabrication
Although, I am a fan of the LoD as well. The Prerunners are pretty much a copy of those. As noted above, the LoD come powder coated. I've beat the absolute shit out of them and they show no signs of failure.
Old 11-20-2015, 07:45 AM
Former Vendor
Rock Hard 4x4's Avatar
Thank you for looking at our sliders! I think you meant Rock Hard 4x4, not HardRock
Our sliders are not only a great value when it comes to quality and price, but if you factor in labor time and cost to install, ours can be installed with simple hand tools in anyone's garage since they do not require welding. How tough are our sliders? Being body mounted may scare some, but when you realize you can lift your Jeep from our sliders, they prove to be invaluable for not only trail duty, but recovery duty.
Also don't forget that our sliders mount not just to the pinch seam but your body mounts. Because they cover the pinch seam, you don't need to buy extra body armor to cover the unsightly seam.
Quick Reply: Slider decision.. Rockhard or VKS?
