Smittybuilt G.E.A.R tailgate
Old Dec 1, 2011 | 09:16 PM
tapp's Avatar
Default Smittybuilt G.E.A.R tailgate
Remember seeing people having problem with the tailgate cover drooping after alot of weight added to it. What are some ways to fix it since I am putting it on this weekend. I rather do it right the first time.
Old Dec 1, 2011 | 09:24 PM
Same here just bought mine cant wait to put mine on.
Old Dec 1, 2011 | 09:39 PM
augichef's Avatar
I screwed the top left corner then pulled it tight and then drilled the next screw in. I also stuck 3m heavy duty Velcro strips around the edges between each self tapping screws. I got a lot of weight on mine and I haven't had any issues with sagging. I also add a long strip of Velcro across the top so I can drape a black cloth over my gear to somewhat hide it when the top is off.
Old Dec 1, 2011 | 10:07 PM
tapp's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=244260"/>
Holy crap that is alot of weight. Thanks for the info
Old Dec 2, 2011 | 05:46 PM
TROUPP's Avatar
augichef: That is a nice setup, hoping Jeepin-clause brings one to my house.
Old Dec 3, 2011 | 06:38 AM
Evo35's Avatar
Attachment 244260
Wow, that picture speaks to how well you installed it. I started with top left and moved across also and it hasn't budged. However, I don't have near as much as you.
Old Dec 3, 2011 | 06:47 AM
DeepJeep's Avatar
I just got mine and will install later today, i will be installing mine with polynuts as i hate sheet metal screws. Polynuts are simple and and when i remove it there wont be any jagged holes left just a threaded hole i can push a black cap into, i will be using 10x24 stainless button head screws.
Old Dec 3, 2011 | 08:19 AM
Evo35's Avatar
Make sure you post some pictures. I don't know what the polynuts are. Oh, and you might need to heat up the plastic so it stretchs flat.
Old Dec 3, 2011 | 08:20 AM
Navyvetnorwich91's Avatar
Veteran: Navy
Can I ask where you got yours? Thinking of it for my Christmas gift list for wifey.
Old Dec 3, 2011 | 08:36 AM
SlowJK's Avatar
where can you get poly nuts locally? I didn't know if a chain store carries them.
